Bosch Marathon Wipers
Old May 4, 2013 | 03:46 PM
neo_anderson302's Avatar
I had a problem with them. I just got oem wipers with the indicatation sticker. Works really well
Old May 7, 2013 | 09:54 AM
acr's Avatar
acr
Same problem here but with Goodyear blades and ICON blades. I'll try trimming them down with a razor blade to see if it'll help.
Old May 7, 2013 | 02:04 PM
cmurphy84's Avatar
So here's what is happening:
The blade has a lot of side to side movement. This is not entirely due to the flex of the blade but also the amount of play at the connector.
That movement, combined with the shape of the end, allows the blade to hit the inside of the wiper arm, and become smashed under the arm. That lifts the arm (and wiper) off the window.
Here is a video and a couple pictures.
Smashed blade end:
See the lift?:
I plan to call Bosch to discuss the problem. Not sure if they will care, but I think it's worth a call to let them know about it.
Old May 7, 2013 | 02:10 PM
saywat?'s Avatar
^yup jus razor of the entire fin including the end cap make it all nice and flat
anyone tried the newer style oem blades from infiniti? i wonder if theirs is stiffer to compensate for the extra play
Old May 7, 2013 | 02:14 PM
cmurphy84's Avatar
Did you cut down the top, sides, or both?
Old May 7, 2013 | 02:24 PM
saywat?'s Avatar
jus the entire top "fin" part
zoop425
Mar 29, 2016 05:51 PM
Phillip_G35
Engine - Intake/Fuel
Feb 25, 2016 05:38 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
NailBomb
Oct 28, 2015 07:53 AM
mcneil_g35
Aug 5, 2015 12:03 PM
