A/C issues, please help!
Old May 29, 2013 | 12:44 PM
albert3029's Avatar
Hey, my A/C started to act up. It's only blowing cold air when I have it at the coldest setting at 60 degrees. I notice when I increase the temp to 65 or 70 it sounds like its turning off and blows hot air. When I put it back to 60 same thing happens and blows cold air. Can it be a sensor thats going bad ?
Thanks in advance!
Old May 29, 2013 | 01:03 PM
neo_anderson302's Avatar
Its overcharged.
Old May 29, 2013 | 01:13 PM
albert3029's Avatar
I've owned the car for almost 5yrs, never charged it. Has always worked fine until now.
Old May 29, 2013 | 01:24 PM
I would put in gauge on it and check. Happened to me before.
Old May 29, 2013 | 04:28 PM
Mustang5L5's Avatar
I would suspect a blend door issue vs an actual problem with the A/C system.
Pop your hood and turn the A/C on, you'll hear the compressor click and one of the lines will get pretty cold. Have someone raise the temp to 70 degrees. Does the compressor click off? Does that line that is cold stay cold?
If the A/C stays running, then my guess is a blend door issue.
Old May 29, 2013 | 05:36 PM
saywat?'s Avatar
blend door issue? wats that mean?
Old May 29, 2013 | 06:33 PM
SergeantRed's Avatar
Possibility but not sure: could be the cabin sensor. It could also be the radio causing the issue as covered in other posts on this forum. GD radios!
Old May 30, 2013 | 07:58 AM
Mustang5L5's Avatar
The blend door is what regulates the air from the vents. It's an actual door inside the HVAC system that directs air between the A/C evaporator and heater core to mix the air and get a certain temp flowing from the vents.
If he's getting cold air at 60, but it stops at a warmer temp, i feel it's not the mechanical A/C system, but an electrical issue like blend door, or even interior cabin temp sensor.
Mustang5L5's Avatar
Possible help
http://www.nicoclub.com/FSM/G35/Seda..._Sedan/atc.pdf
Old May 30, 2013 | 08:33 AM
albert3029's Avatar
Thanks for the info and the link. Have to find time to check this out, maybe I'll have a shop take a look at it for me.
Old May 30, 2013 | 09:48 PM
albert3029's Avatar
Got in my car after a few days of not driving it and the A/C seemed to be working fine
Old Jul 10, 2013 | 04:44 PM
crazy8ship's Avatar
Where is the cabin sensor? I have to opposite issue. I can turn mine up to 76 degrees and I am cold in my car.
champppy
Mar 31, 2020 12:25 PM
cmesidewayz
Sep 29, 2015 09:28 PM
baker2795
Sep 2, 2015 06:00 PM
Frostbite91
Aug 20, 2015 07:20 PM
