chrome door trim OEM, bottom of window
Old Jun 12, 2013 | 05:18 PM
neo_anderson302's Avatar
I need help finding out the name of the oem chrome door trim on the front drivers door. The piece that runs along the window at the bottom. I may a pretty big dent on it and now its time to replace it. Also, how do you remove it?
Old Jun 20, 2013 | 09:19 PM
David3100's Avatar
I have removed that trim from an '03 and an '05. It seems to work best to lower the window all the way down. At the end of the door, furthest from the mirror, take a trim removal tool that has a J hook and from the inside facing out, pry up on the trim. There is a hook that has to be released by both prying upward and toward the inside of the car at the very end of the trim furthest from the mirror. Hope this helps. The stainless will be distorted by pressure so don't apply too much force. Once it releases continue to raise using your fingers and pull up and toward the rear of the car.
Old Jun 20, 2013 | 10:09 PM
ok thanks. Ill try it tomorrow.
jsimonk
Dec 22, 2023 03:49 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
R350k5
Oct 1, 2015 08:41 PM
will091195
Jul 27, 2015 09:19 PM
