My G35 turns off
Jul 14, 2013 | 07:23 PM
ill be driving on freeway and RPM drops to zero , and eventully RPM goes back up.
When I'm driving on the street , RPM drops to zero and car turns off. It will restart after 3 - 4 tries . What could be causing this? fuel pump?
thanks
Reply 0
Jul 14, 2013 | 11:16 PM
Do you get any code? Maybe you camshaft or crank sensor are going out. Pull the codes if thr check engine light is on
Reply 0
Jul 14, 2013 | 11:22 PM
Go to the dealership. You can request a courtesy check (free). Don't let them charge you for this . We are shooting into the dark here trying to help you.
Reply 0
Jul 16, 2013 | 08:41 AM
Crank shaft sensor maybe? Don't know without knowing what codes its throwing.
Reply 0
