People with lowered sedans
Old Feb 2, 2005 | 02:47 AM
Nickk6's Avatar
I lowered my previous car and it always pulled to the right now matter how much I had it aligned. For the guys that lowered their sedans, does your car pull? Or does it go straight after an alignment?
Old Feb 2, 2005 | 06:23 AM
HOO-MAN?'s Avatar
Only One Month So Far And Mine Still Doesnt Pull. No Alignment Yet---i Might Just Do It Anyways. The Ride Improves Over The Sport Package Too.
Old Feb 2, 2005 | 08:47 AM
MiamiG35sedan's Avatar
If done properly, you should have no issues. My car steers perfectly straight. See my review . . .
https://g35driver.com/forums/reviews/35796-review-tein-basics-350evo-arms-spc-camber-kit.html
Old Feb 2, 2005 | 10:13 AM
skeleton_cru's Avatar
Sedan
No problems here. My sedan drives straight as an arrow. You should ALWAYS get an alignment after lowering though. You could have camber or toe issues that need to be addressed. You may also need A-arms to correct camber issues.
Old Feb 2, 2005 | 10:24 AM
BrianV's Avatar
If you get a proper alignment you should be ok, but if the alignment shop just puts each wheel within the spec'd range and doesn't make sure both wheels are the same spec then you may have issues. Mine seemed to pull to the right after I put my rims on but it seemed to have went away on it's own and goes straight now.
Old Feb 2, 2005 | 11:44 AM
g35sedamn's Avatar
so far i have lowered two sedans.. mine and a friends (who refuses to join the forum because he is computer illiterate). mine has yet to have an allignment done on it and it drives straight as an arrow. his has no pulling issues either. was your other car a front wheel drive? they pull to the right or left depending on what make it is because of torque steer.
Old Feb 2, 2005 | 12:11 PM
Sedan
Just because your car doesn't pull to one side doesn't mean you don't have alignment issues. Keep an eye on your tires for uneven tire wear. I have -1.4 degrees camber front left and -1.8 degrees camber on the front right. After almost 3k miles I am already seeing uneven tire wear.
Old Feb 2, 2005 | 01:23 PM
g35sedamn's Avatar
we have an alighment machine here at the shop i work at and i am running 1.4 degrees left and 1.5degrees right and i don't really plan to do anything about fixing it. my tires seem to be wearing pretty well. i can not check the rear too well because our machine is tempremental with two sensors.
Old Feb 2, 2005 | 02:09 PM
jstwong's Avatar
I lowered my sedan with HKS Hipermax LS coilovers [and then had an alignment done], and I have not had any kind of steering issues.
Old Feb 2, 2005 | 04:07 PM
HOO-MAN?'s Avatar
Do I Need New Shocks For My Sedan? Im On Eibachs Prokit Springs... What Might I Need ?
Old Feb 2, 2005 | 04:18 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
What was your OEM setup?
Sport or Base?
If sport you will be OK
If Base then I'd def think about changing
Old Feb 2, 2005 | 04:24 PM
oh-dawg's Avatar
For you guys with the negative camber, is it that way because there is no more adjustment for the camber (maxed out)? or did you guys set it that way?
Basically, I just want to know if lowering the car, say, 1 inch, is going to give it negative camber issues and inner tire wear..
Old Feb 2, 2005 | 04:32 PM
HOO-MAN?'s Avatar
Sport, But I Noticed The Bottom Of My Tires Are Further Out Than The Top...kind Of /\ From Behind.is That Fixable?
Old Feb 2, 2005 | 04:37 PM
InTgr8r's Avatar
Yup, it will require a camber kit (nothing to do with shocks)
I installed the upper control arms from performance nissan.
If you seach the topic you'll find othe camber solutions as well.
Old Feb 2, 2005 | 04:49 PM
BLICX13's Avatar
It's amazing to me that people spend 30k on a vehicle and $200 on lowering springs, but won't fork out $70-$100 to insure that their tires will wear evenly - $100 alignment is a heck of alot cheaper than $600-$1000 for some good rubber...
