Trouble Programming alarm remote
Old Aug 19, 2013 | 07:29 PM
Lbonilla9's Avatar
1. Close and lock all doors with the driver’s side power lock/unlock switch.
2. Insert key into ignition and remove it from the ignition key cylinder at least six times within 10 seconds. Your Hazard
Lamps will flash if you have performed this step successfully. NOTE: Withdraw key completely from ignition cylinder
each time. If this procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push ANY button on the remote transmitter. Your Hazard Lamps should flash. NOTE: Do not press
the button more than one time in the above step. If the button is pressed more than one time, the programming
procedure will not be successful.
I'm having trouble with step 2 the hazar light won't blink but when I get to step three and four the hazard light do blink the second time I took it to the lock smith when I got my key cut and try to program my remote but he could not either he also said it might bet aftermarket stereo that wnt let it program need help really bad
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
dseet
Oct 11, 2015 12:40 AM
Detailed Image
Sep 18, 2015 03:43 PM
