HID xenon low beam replacement
Old Oct 14, 2013 | 06:35 PM
adwizard's Avatar
I was told you could access and replace the low beam headlight bulb from the engine bay... I guess removing the air filter is necessary. Is this true or must I jack it up and remove the fender well and attack it from the rear. Lastly does anyone know what HID oem bulb came with the 2004 g35x? Is it the D2R 4300K? Answering all the questions will earn you brownie points. But seriously it would help a lot. Thanks.
Old Oct 14, 2013 | 09:54 PM
Nate_6mt's Avatar
Easiest access point Is definitely through the fender wells. A few minutes to take them off and your good to go. As far as the bulb..your correct it is a d2r 4300
Jusseth
Sep 13, 2020 12:25 PM
julian.dion
Lighting
Jul 29, 2015 12:47 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
EasySausage
Jul 20, 2015 03:56 PM
