A/C on = louder engine noise
Old Oct 15, 2013 | 09:13 AM
Speedster's Avatar
I've read countless threads upon searching and see that this sound is very common. There was also a TSB for it on 2003 sedans. But even that didn't seem to solve the problem or it would come back in a few months.
My question to first gen owners, does the noisy A/C compressor cause it to fail or have you had a noisy compressor and never had to change it? Just curious if it's something I need to worry about and look into a fix before it goes out or if this is just the nature of the beast and it will last a long time and just live with the loud engine noise with A/C on and under 30mph speeds.
Old Oct 15, 2013 | 10:15 AM
Quimby's Avatar
It's fine, don't worry.
Old Oct 16, 2013 | 12:42 AM
drkay's Avatar
I get the loud sound too on my '04.5x. I have a stillen gen 2 and berk HFCs and the sounds is very amplified in this setup. So much so that I refrain from using the AC. I was not aware this was actually a common problem. What's the fix??
Old Oct 16, 2013 | 01:40 AM
thegreatkwijibo's Avatar
you have a stillen gen 2 and berk HFCs what do you care about noise?
Old Oct 16, 2013 | 03:02 PM
drkay's Avatar
I am interested because the quality of the noise changes such that I get a lot of in cabin drone. Normally, with a/c off, there is virtually no drone and I just get a nice rumble in the interior.
Old Oct 16, 2013 | 08:05 PM
Mustang5L5's Avatar
Mine has done this since new. No change. Once in a while it sounds rough, other times not so rough.
Interior drone is not what I'd describe it as however. Sure it's not drone from the exhaust as the engine rpm/load changes?
Old Oct 17, 2013 | 06:42 PM
Karl Horn's Avatar
Mine too
Old Oct 22, 2013 | 09:43 AM
EMG03's Avatar
the compressor in my 03 sounds real loud sometimes and other times you cant hear anything. its been like that since I got it 3 years ago and ac is still ice cold
Old Oct 23, 2013 | 09:04 AM
Speedster's Avatar
Cool thanks guys, good to know, I won't worry about it then unless it dies
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
baker2795
Sep 2, 2015 06:00 PM
Frostbite91
Aug 20, 2015 07:20 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
joedaddy1
Jul 28, 2015 02:58 PM
