Grill Replacement help!
Hi, I was wondering if I am still able to replace the grill on my 2004 G35 Sedan.. But I need some help understanding the assembly of the grill and bumper attachment.. as far as i understand, the grill is attached to what is circled in the green and the blue... correct? If yes, what was attached to the slots circled in red? and it looks like there were some more slots that were broken that are circled in Yellow... so what parts exactly does the grill connect to and what shouldnt I worry about it... can it even be replaced for a fair amount of money? I will appreciate all your help and comments..
Maybe i am purple deficient?
We have already answered your question... yes it can be replaced.
pass red one is good drivers not so much... the clips where the yellow are GONE. If you were to drop in another sedan grille, you would put all the top clips back in and only one on the pass side.
As far as I can see yes... actually that piece remaining in the red on the drivers side is one of the four lower clips that got removed in your accident. You can reuse that also... you should be fine to drop in another sedan grille.
Will it have to be an OEM factory grill or can it be a billet grill such as this...
http://www.ebay.com/itm/2003-2004-IN...p2054897.l4276
because i notice this replacement billet grill only has 2 attachments on the top, or at least that i can see. I see no place on this grill for it to attach to the green but only to attach to the 2 middle blues.
Usually anything that is not OEM will fit, with a little "custom" work. That will fit but it requires drilling of what seems to be two new holes in the "Glass-Fiber" composite area where the blue dots are. I highly doubt it will fit the original tabs.
11 people viewing this thread... erm... Guests, make an account and join the fun.
Whosurbuddiee, where is your troll post?
