A/C only works when set to 60 degrees
Old Oct 24, 2013 | 11:14 AM
JC77's Avatar
I'm having an issue with my A/C recently. I just noticed it when it started getting cold here in Minnesota. My A/C will only engage when set to 60 degrees, when I bump it up to 61, it blows hot air. I saw the other threads about making sure the sensor and tube are plugged in under the steering wheel, which mine are. I noticed my coolant level in my reservoir is low, could that be the problem? Faulty cabin sensor? Bad fuse? Any ideas would be greatly appreciated.
Thanks
Old Oct 24, 2013 | 03:29 PM
Mustang5L5's Avatar
Does the actual compressor disengage? Can you check under the hood with the A/C running at 60 to see the compressor is engaged and then bump it to 61 and see if it stays engaged or shuts off? Is the A/C light still lit on the HVAC controls?
It could be an interior temp sensor issue, or a blend door sensor issue.
Old Oct 24, 2013 | 03:39 PM
JC77's Avatar
Thanks for the reply. When I'm sitting in the car, I can hear it change over when I bump it to 61.
Old Oct 24, 2013 | 04:16 PM
Mustang5L5's Avatar
Possible interior temp sensor issue.
http://www.nicoclub.com/FSM/G35/Seda..._Sedan/atc.pdf
FSM for an '06. You didn't state year but others are available if you search through this folder
http://www.nicoclub.com/FSM/G35/Sedan/
The FSM has some good diagnostic procedures and some of the stuff you can do yourself to troubleshoot
Old Oct 24, 2013 | 04:19 PM
KingoftheRoad1's Avatar
What's the ambient temperature? I know the AC operation is related to the ambient temp. If the ambient temp is low, the compressor will not engage. The lowest setting, 60, is forcing the compressor to work, but when you set it 61, the compressor disengages.
Since fall is upon us now especially in your area. I would wait till next year to see whether the AC is working right. This way we can rule out the ambient temp. My 0.02.
Old Oct 24, 2013 | 07:02 PM
joedaddy1's Avatar
correct me if i am wrong but doesn't the compressor need to engage to dehumidify the cabin? like when you defrost your front windshield.. i might be wayyyyy wrong though..
how low is your coolant? I know when the Infiniti dealer didn't bleed my coolant correctly, heater wasn't working properly..
Old Oct 24, 2013 | 09:28 PM
Mustang5L5's Avatar
You are correct.
There is a low temp cutoff for the ac compressor, but it's pretty low. 15 degrees or something like that. I've regularly run my ac on 30-40 degree days to Defog the windows during a snowstorm.
The FSM lists the cutoff temp.
Old Oct 25, 2013 | 12:32 AM
joedaddy1's Avatar
Originally Posted by Mustang5L5
You are correct.
what's the reason for the cutoff? is it to save the compressor from damage?
i know i can run the a/c compressor at 80+ degrees in the winter to defog..
Old Oct 25, 2013 | 09:40 AM
Mustang5L5's Avatar
Mainly to prevent the evaporator from freezing up. Possible other reasons as well.
I do not know what the temp it cuts off is however.
Old Nov 21, 2013 | 05:02 PM
infinitidude's Avatar
The part you need is called a intake sensor which is located in the in cabin/evaporator area. The part number is 27723-AG000 When the a/c cools only at 60 then this is the issue. Very common on I30 and QX4 models but have seen a few on the G35
Old Nov 22, 2013 | 05:13 PM
Vectork39's Avatar
Thanks. I've been having the same problem
Old Nov 22, 2013 | 05:17 PM
Vectork39's Avatar
How hard is this to swap out?
Old Nov 22, 2013 | 05:34 PM
You will have to remove some screws from a/c box underneath dash and wedge it open where box is put together. If you have some extra long needle nose pliers it is fairly easy because the sensor just pushes into evaporator fins
Old Dec 3, 2013 | 10:45 PM
01yellowr's Avatar
I had the same problem. It was the interior temp sensor
Old Dec 4, 2013 | 03:52 PM
JC77's Avatar
Are the intake sensor and interior temp sensor different parts? If so, any way to decipher which one I will need?
