2004 infiniti g35 overheating
Old Nov 7, 2013 | 05:32 AM
fastime12's Avatar
I have g35 overheating. replaced thermostat but no help..it acts live thermo is not opening no heat out of heater .Can it be possible water pump impeller is eroded not circulating water ,how to check before I rip car apart?
any advice out there would be great
Thanks fastime12
Old Nov 7, 2013 | 05:44 AM
HotRodG35's Avatar
Have you attempted to bleed coolant system ?
G35/350z are notorius for having issues with air pockets in coolant system.
Easiest and least messy way is to with engine cool open bleed port near back of engine( off heater supply line) add coolant to radiator until coolant flows out port, tighten bleed plug. Start engine and allow to warm up with temperature set to high, Repeat as needed.
Old Nov 8, 2013 | 03:19 AM
vqsmile's Avatar
Thanks fastime12
You'd get better response if you posted this in the 1st gen section.
rezendvous420
May 31, 2020 01:26 PM
R350k5
Oct 1, 2015 08:41 PM
vstypicals
Jul 20, 2015 10:55 PM
