High rpm.. no acceleration problem
Old Dec 3, 2013 | 06:54 PM
twenty5's Avatar
At my car now and about to get it towed. Couldn't get any readings from the ecu. Says its clear according to torque app.
Old Dec 3, 2013 | 09:27 PM
twenty5's Avatar
More or less, I've done some researching and found mostly that it's an ECU problem and shortages... I mentioned that it all started happening the day AFTER i plugged in a ELM327 code reader out of curiosity and may have plugged it in "too hard...?". I'm hoping that I broke a connection because of this. If that's the case, I'm atleast able to pinpoint the problem. I'll check it out tomorrow since it's getting late and let everyone know.
I'm also referring to this post since she is having the exact symptoms as I am having. INCLUDING the no display when in park, drive, on the dash..etc.
Old Dec 4, 2013 | 02:56 AM
nazc0's Avatar
2006 Vortech supercharged Sedan
what android app are you using? i use torque and never had a problem pulling multiple types of codes from almost any car
Old Dec 4, 2013 | 08:27 AM
twenty5's Avatar
I got OBD droidscan pro...couldn't get torque to work but OBD droidscan pro was able grab those 2 codes for me
Old Dec 4, 2013 | 06:50 PM
twenty5's Avatar
Could it be my starter? I thought the radio was working, but it actually isn't... Its turning on and off
Old Dec 4, 2013 | 07:56 PM
twenty5's Avatar
There's a good chance the whole ordeal may be originating from my radio. There's an aftermarket one installed to fix the a/c issue with the 03 g35's. In order to get the ac to work correctly, one of the cables had to be unplugged and perhaps the car did not like this?
Old Dec 5, 2013 | 12:21 AM
nazc0's Avatar
what 2 codes?
Old Dec 5, 2013 | 12:27 PM
twenty5's Avatar
Originally Posted by nazc0
what 2 codes?
U1000 and U1001
Old Dec 7, 2013 | 11:49 AM
twenty5's Avatar
Bump... I checked the radio, and it looks all fine to me. Can someone assist me in finding the ground wires ? Perhaps one is disconnected. Problem not solved still.
Edit--
I found a disconnected ground wire underneath the car by the exhaust tail. I did a orbital radius around the area with the broken ground cable (it's a flat one) and doesn't seem to connect anywhere... has to be a spot, but I cannot find it. I'm uploading some images. Can someone please assist me?
I've uploaded images of the area and engine bay if someone can help me circle some grounding wires.
Also, I'm searching for the AT. Cont fuse.... not sure where the third fuse box is located @ since someone else had theirs blown a few times
http://imgur.com/a/oiSbz#0
edit 2----
I've located the third fuse box... is there a diagram for this thing?
EDIT 3----
I found the culprit. Time to start pinpointing!
http://imgur.com/a/BEIvx#0
There was that sneaky darn hidden fuse box behind the battery compartment. It was my second time looking back there and finally found it.
From there, the top left corner fuse (10A) is the AT. Cont fuse. It's blown! (YAY?)
Replaced it with the spare one and fair enough, the car actually starts up now.
SECOND PROBLEM
It the car rolled a few times before starting up, so i'm assuming it's having problems starting... i stepped on the gas pedal to give it a bit of umpf and sure enough, it started.
SECOND PROBLEM SYMPTOMS:
a bit of white smoke coming out of the exhaust pipe. It's cold, i get it.. it'll be a bit white. But this was not the typical hot/cold white. it was white.. white.
ASSUMPTIONS??
I'm assuming perhaps a blown gasket? I still have not found why the fuse was blown yet either. (disconnected ground? short somewhere? perhaps that one image earlier from above.)
so i'm hoping someone would shed some light since i've gotten this far.
Old Dec 7, 2013 | 03:03 PM
markc's Avatar
http://engine-codes.com/u1000_2003_infiniti_g35.html
Check this link, it may help.
Old Dec 7, 2013 | 03:47 PM
twenty5's Avatar
Originally Posted by markc
oh wow, thanks for this! I'll take a look at it asap. Car is working great now too
derres
Aug 28, 2015 03:27 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
