How Many Quarts for Transmission Drain for A/T?
Old Dec 11, 2013 | 11:30 PM
taimysho0's Avatar
hello, i tried searching but couldnt find an exact answer. i see that a tranny flush takes more quarts to refill, but if i just want to drain my tranny, how many quarts of nissan matic s should i buy?
thanks
Old Dec 11, 2013 | 11:35 PM
Urbanengineer's Avatar
http://www.nicoclub.com/FSM/
Old Dec 12, 2013 | 08:38 AM
Mustang5L5's Avatar
I've done 4 drain/fills on my G35 so far.
Each time used exactly 4 qts. I always had 5 on hand just in case.
drail/fill #5 due as soon as the temp warms up to the upper 30s
Old Dec 15, 2013 | 10:39 PM
G35CO's Avatar
3.5 each time I did mine
Old Dec 15, 2013 | 10:45 PM
TurTLe*'s Avatar
General rule for a D/F for 90% of cars is 6qt.
Seems 3.5-4 qts come out of our pans. Also do factor in a small amount of spillage and etc. I normally get 6qts because in most cases you can use that as P/S fluid as well.
Old Dec 16, 2013 | 09:11 AM
Mustang5L5's Avatar
I've tried different things to get more fluid up. Jacking up the rear, or jacking up the front. Most i can get is ~ 4 qts out
Old Dec 16, 2013 | 01:20 PM
SugarShawn's Avatar
How often should the fluid be changed? I just bought my car last month
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
Row2k
Drivetrain
Dec 27, 2015 04:08 PM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
