03 sedan Projector advise/help
Old Dec 29, 2013 | 09:35 AM
sinnistar's Avatar
Hi all,
Im in serious need of some advice,
i've searched quite a bit and seems like if i do a retrofit from the retrofit source i can use the Bi-xenon Morimoto Mini Stage III Kit (H1), or the D2S version of that kit. Has anyone done that particular retrofit, and how complicated was it. Any write-ups ?
also considering buying some after market ones....not the crappy side led ones all over ebay but more like
http://www.ebay.com/itm/03-04-G35-SE...e36181&vxp=mtr
Does anyone have any experience with those ? seems like they used the h1 Morimoto kit
I have a set of OEM non hid headlamps on hand and a set of the black aftermarket ones on the car now....I heed better light output seeing that i JUST SHIPPED IT TO THE UK !!! the only US spec 1st Gen sedan in the UK. I really dont need the hassle from the Police hear with afermarket HID's i have installed now. So i believe projectors are my best bet.
looked through the classified but none there.
Any help would be appreciated !!! or if [someone wants to sell theirs im open to that as well.
Thanks again.
Old Dec 29, 2013 | 02:51 PM
Mike04x's Avatar
Doing a retrofit yourself isn't too difficult if you're going to be using the Morimoto H1 minis, minimal cutting for the low beam spot for the reflector to clear, and no cutting at all if you were to put them in the hi beam spot. I used https://g35driver.com/forums/media-s...-retrofit.html as a guide for mines but ended up doing mini's up top and FX-Rs in the bottom which involves much more cutting than just doing the minis. hope this helps.
Old Dec 29, 2013 | 08:32 PM
sinnistar's Avatar
so if i do use the lower for the high low, is there any wirig guids out to relocate the fog light...checking into the retrofitsource i see the h1 matchbox that i can drop i as fogs in the upper...or just leave it as is and put fogs in by the bumper.
jsimonk
Dec 22, 2023 03:49 PM
Jusseth
Sep 13, 2020 12:25 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
