Suspension Noise
Old Jan 7, 2014 | 08:19 PM
lazychina123's Avatar
Suspension Noise
I have the 2004 G35 with 80k miles, it's manual transmission, there is some noise like" thudding" from the front suspicion at any speed, so i had done my wheel balance and also did a tire rotation to see if the noise can go aways or not, I even bought one pair new tires from walmart and install in the front , but it seems all doesn't work, the noise is still there, any idea folks? compression rod? thx
Old Jan 7, 2014 | 08:50 PM
jookyshank's Avatar
I haz hugz to givez
I had that thud on my 105K mile coupe, ended up being a blown front shock. It started thudding before it "felt" out (handling etc) so if your bushings check out, that may be another area to explore.
Old Jan 7, 2014 | 09:20 PM
infinitidude's Avatar
I am assuming that if you replaced the tires that it may be speed related so you might want to check your front hub bearings for excessive noise
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
