Hi all, I have a 2005 G35 base Sedan and it has HID lights. Front Left Low Beam headlight gave up recently and when i go to Pep boys, they gave me a quote of $180 to just buy & replace one HID bulb.
Is that reasonable?
Can i buy the bulb myself on Ebay and go to a body shop to get it changed?
Thanks in advance
Is that reasonable?
Thanks in advance
If you just want bulbs to work....
Go to vendor marketplace, im sure there is some vendors selling bulbs. They can help you out, but off hand i believe its a D2R bulb...
Replacing it is a little bit of a challenge your first time but can be done in minutes the following... If your even semi handy with tools..
I would think the $180 bulbs are factory OeM bulbs, i would hope...but a set of aftermarket can be found for under $40.... Its been awhile since i bought mine. But if you want to keep the same look as factory, get a 5k bulb... 6k, 8k and so on get bluer the higher the kelvin.
Hope that helps...
Hope that helps...
That's about what the dealership will charge for replacement HID bulbs. We have high quality replacement HID bulbs listed here on our site for $39.99 and you should be able to install them yourself with fairly little effort: http://www.diodedynamics.com/store/l...hid-bulbs.html
Let me know if you need more information
Thanks and welcome to the forum!
Nick C.
Nick C.
Part of the issue (assuming 05 is same as 03) is that you go through the wheel well to change bulb, so a little labor intensive. I would also recommend changing all the bulbs in that fixture at this time.
I am not a diy person so my idea of "fairly little effort" is changing a Honda headlight where you raise the hood, reach in, pull back the clip and pull out the bulb.
Quote:
I am not a diy person so my idea of "fairly little effort" is changing a Honda headlight where you raise the hood, reach in, twist and pull out the bulb.
I can certainly see your point lol, everyone has a different skill set and considers certain DIY jobs easier than others.Originally Posted by wasjr
Part of the issue (assuming 05 is same as 03) is that you go through the wheel well to change bulb, so a little labor intensive. I would also recommend changing all the bulbs in that fixture at this time.I am not a diy person so my idea of "fairly little effort" is changing a Honda headlight where you raise the hood, reach in, twist and pull out the bulb.
I say it's fairly simple because you don't have to have power tools or a lift to get the job done
Nick C.
Blue Dream
I drove ttrank's car solo
close
- Join DateMar 2009
- LocationBy the sea, Tx
iTrader Positive Feedback100
iTrader Feedback Score(50)
- My RideG35 sedan w/ too much money in mods
Liked:1,488 Times in 1,223 Posts
Nick, I didn't see 5000K D2Rs on your site, do you guys offer them?
Quote:
We don't offer 5000K, but our Kelvin scale is much whiter than many of our competitors. Here's a better comparison chart:Originally Posted by Blue Dream
Nick C.
Hope that helps...
Actually factory is 4300k.Originally Posted by gsRt5
If you just want bulbs to work.... Go to vendor marketplace, im sure there is some vendors selling bulbs. They can help you out, but off hand i believe its a D2R bulb...
Hope that helps...
Quote:
The lumen output depends on the ballasts driving them, along with several other factors. However, our bulbs with output 3,000 lumens, which is consistent with any high quality HID bulb.Originally Posted by 5150DS
Diode Dynamics, how many lumens do your bulbs put out?
We will have exact ratings available in the very near future, as we made a sizable investment in scientific light measurement equipment (integrating sphere, etc.)
Nick C.
Quote:
Nick C.
very nice new chart .. looks way more accurate than all others ive seen ..Originally Posted by Diode Dynamics
Nick C.
il be ordering soon . now that i can tell what i want . lol
Nick C.
Do your bulbs color shift as they age or keep the same color throughout their life cycle?Originally Posted by Diode Dynamics
The lumen output depends on the ballasts driving them, along with several other factors. However, our bulbs with output 3,000 lumens, which is consistent with any high quality HID bulb.We will have exact ratings available in the very near future, as we made a sizable investment in scientific light measurement equipment (integrating sphere, etc.)
Nick C.
Sorry for so many questions.
All HID bulbs will change color slightly over time, that includes OEM bulbs as well.Originally Posted by 5150DS
Do your bulbs color shift as they age or keep the same color throughout their life cycle?Sorry for so many questions.
Our HID bulbs typically last 3-5 years, and I haven't seen anyone come in with a noticeably different color.
Nick C.
Quote:
4300k seems lot less than 6000k. Will there be a lot of visible difference between the two?Originally Posted by 5150DS
I was gonna buy the 6000k from the Diode dynamics link above.
I have 6000K installed in both of my personal cars and we have 6000K in our FR-S
You won't sacrifice too much light output by switching to 6000K
Nick C.
Nick C.
