Tail light fuse
Old Feb 10, 2014 | 07:39 PM
g35SedanSC's Avatar
Tail light fuse
The tail lights fuse keeps popping,even when the lights are disconnected.
Any idea guys?
Thank you in advance.
Old Feb 11, 2014 | 08:56 AM
Speedster's Avatar
Any recent stereo mods or bulbs replaced? I had the same issue and took me a week of searching before I realized I replaced the clock bulbs and one of them was grounding and blowing the fuse.
Old Feb 11, 2014 | 11:49 AM
Mustang5L5's Avatar
You have a short somewhere.
Any recent electrical work? Or work in the car that could potentially pinch a harness?
Old Feb 11, 2014 | 01:33 PM
g35SedanSC's Avatar
2Din couple of month ago,but i re did the harness and checked everything,Bulbs have been upgraded to 75/85w(fog)it happened when i went over a bump.
Old Feb 11, 2014 | 01:34 PM
g35SedanSC's Avatar
So for that fuse
Tailights
Ilumintion
dashboard lights
What else can i check?
Old Feb 11, 2014 | 01:38 PM
Speedster's Avatar
Easiest thing to do is unplug the bulbs you replaced. Then plug in one at a time and keep checking to see if it still blows fuse. If that's not it, probably a pinched stereo wire...
Old Feb 11, 2014 | 01:41 PM
g35SedanSC's Avatar
I will do that right now,and will get back in a bit,Thank you.
Old Feb 11, 2014 | 01:43 PM
Speedster's Avatar
Cool, seems like aftermarket bulbs are always a Crap shoot and either work or short stuff out
Old Feb 11, 2014 | 08:13 PM
g35SedanSC's Avatar
ok so its not the fog lights
Old Feb 12, 2014 | 10:54 AM
Speedster's Avatar
What other bulbs did you replace besides fogs?
Old Feb 13, 2014 | 10:41 AM
Blue Dream's Avatar
I drove ttrank's car solo
Also check the wiring for the lights in the trunk for any fraying, cuts or crimps. Might have an issue with those which could cause your issue.
Old Apr 27, 2014 | 01:46 AM
g35SedanSC's Avatar
Thanks for the help guys,the issue just went away by it self.Changed the fuse 2 weeks later and it worked
roboeclipse
Lights
Aug 13, 2015 10:45 PM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
