Upper Control Arms
Old Mar 8, 2014 | 10:42 PM
1lapdawg's Avatar
Upper Control Arms
My upper control arms are in need of replacing on my 2004 G35x. Is it the same part number as the 2wd G35 or does the x have a different part #. Ive been searching and have not found a definitive answer.
Thanks
Old Mar 8, 2014 | 11:57 PM
Urbanengineer's Avatar
Use Rockauto, its so easy to find whatever you need.
http://www.rockauto.com
It seems 2WD and AWD are not the same per their recommendations.
http://www.rockauto.com/catalog/more...376&cc=1431984
--Sedan--
Old Mar 9, 2014 | 09:09 AM
1lapdawg's Avatar
Rockauto
Rock auto does not show another choice for a 2004 G35X.
Old Mar 12, 2014 | 03:31 PM
1lapdawg's Avatar
Whatt part #s
OK since this is not getting any response I'll ask again. For a 2004 G35x does ut share the upper control arms with the regular G35?
I do not find anyone selling separate upper control arms so I am stumped.
Thanks.
J
Old Mar 12, 2014 | 03:54 PM
LoSt180's Avatar
I'm finding two different part numbers on http://grubbsinfinitiparts.com/ for front upper control arms on an 04 G35 Sedan:
Front Upper Control Arm:
RH: 54524-CF00A (2WD)
RH: 54524-AQ300 (4WD)
LH: 54525-AL500 (2WD)
LH: 54525-AQ300 (4WD)
The 2WD part numbers match the coupe and 350Z, so I'd make an educated guess that the X-model suspension parts are different than the rest.
Freeman186
Sep 6, 2023 10:07 AM
jilljann1
Jul 21, 2020 08:12 AM
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
alessandro
Oct 8, 2015 09:29 AM
