Z-Tube install problem?
Old Feb 9, 2005 | 08:07 PM
SouthernG35's Avatar
Unhappy Z-Tube install problem?
Just installed the polished z-tube, and have a question. After the install I reset my ecu. Now after you turn the car off it makes a high pitched whistle sound. This whistle noise lasts for about 5-7 sec. I noticed during the install that I have alot of extra tubing from my PCV. Is the sound coming from that? Do I need to trim it so that the hose is not kinked? Please help me find this noise problem. Has anyone else had this happen after a z-tube install?
Old Feb 9, 2005 | 08:24 PM
Xman's Avatar
I wouldn't cut anything. I suggest just working the tubing back towards the firewall and making sure it doesn't kink. That's what I did with mine. Then check and make sure your clamps are tight.
Good Luck!
Old Feb 14, 2005 | 02:17 PM
MarkG's Avatar
The whistle could be anywhere the new tube or old hoses mate up. Double check everything to make sure there are no air leaks.
Old Feb 14, 2005 | 04:25 PM
3Aims's Avatar
does a properly intalled z tube still produce a whistle or hiss sound like you see with cold air intakes?
Old Feb 14, 2005 | 06:14 PM
G-Pimp's Avatar
No, it makes more of a "roooom-rooooom" noise.
chinee
Jun 10, 2024 07:48 PM
CrazyLogic219
Aug 13, 2015 06:40 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
attarday
Jul 15, 2015 04:03 PM
