Need Help
Old Feb 10, 2005 | 02:37 PM
SweetNlow's Avatar
City that Never Sleeps
Need Help
When I put the cd on, the deck makes a funny noise then is says CD ERROR FO.... Does anybody know how to fix that? It's like the cd is not catching.....This blows......
Old Feb 10, 2005 | 04:08 PM
G35sedanman's Avatar
try a cd cleaning kit purchase from any electronics store
Old Feb 10, 2005 | 09:50 PM
Specialist23's Avatar
dealership
Old Feb 11, 2005 | 02:18 PM
SweetNlow's Avatar
I got it fixed. There was a dam CD-R stuck in loading and the radio gave up on loading it. I took it out....
Old Feb 11, 2005 | 03:22 PM
g35girl's Avatar
Unimaginative, Indecisive User
sweetnlow... there has been a technical service bulletin (see the TSB section of this site under "technical and modifications") for that CD-error. several members (seems to have happened mostly with older g35 models 2003-2003.5) have had their units replaced under warranty. i'd take it into the dealer and tell them about your prob even if you got the CD out. also, some members have cited that using CD-Rs may sometimes cause the error, while others have no trouble with CD-Rs. good luck!
Old Feb 11, 2005 | 03:43 PM
GeoBau's Avatar
Cactus Hugging Admin
Also, make sure you don't put a label on any CD-Rs. The increased thickness HEAVILY contributes to the dreaded CD ERROR F0.
G
Old Feb 12, 2005 | 10:19 AM
ryoken's Avatar
My '03.5 is on it's fourth radio due to that problem. I've discovered that the solution, at least in my case, is to only keep 5 discs in the 6-disc changer. It only jams (and often jams) when it's full.
Old Feb 13, 2005 | 02:13 AM
skeleton_cru's Avatar
Sedan
This is a known problem. I had my CD changer replaced. It jammed with 6 store bought CD's (no CD-R's).
Old Feb 13, 2005 | 05:56 PM
cato's Avatar
SouthernComfort Moderator
This is what the Cd player does when it is FU*^$d Up. Therefor the
Cd Error FO indicator. Mine did this also. You must take it to the dealer, they
will get you a new unit, if you are still under warranty.
