Wheel Hub Assembly/Bearing Replacement
Old Apr 29, 2014 | 01:28 AM
kenmoini's Avatar
So my G35 has been having an increasing whirring sound while driving, steering to the left decreases the sound greatly, when straightening out it gets loud again.
I'm betting it's my bearings going bad. I'm wanting to replace the pair in the front, what I'm wondering is a few things...
Are the left and right front assemblies the same? Cause on all the order pages I've seen it doesn't ask for a specific side...
With buying the hub assembly instead of just the bearing, the bearing comes pressed in the assembly already correct?
Any brands that I should look for?
Thanks again!
Old Apr 29, 2014 | 08:27 AM
Urbanengineer's Avatar
You need to make sure it clearly states if it comes with a bearing pressed in.
As for the side, they are only sold front to back so it's no issue.
You'll find a DIY under the DIY section and it has pics.
Old Apr 29, 2014 | 08:33 AM
LoSt180's Avatar
Left and right are the same. X-models are different than RWD though.
The front hub assembly has the bearing already, it's a simple bolt-off/bolt-on replacement. The rears need to have the hub pressed into the bearing though.
Timken, Moog, OEM are brands to get.
Old Apr 29, 2014 | 08:59 AM
Mustang5L5's Avatar
You didn't specify AWD or RWD, but I assume you have a RWD
In that case, the front bearings are sold as bearing/hub assemblies. They aren't side specific, so the unit will fit either side.
Cajuncowboy
Jun 21, 2021 09:47 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
teamghost
Jul 28, 2015 04:52 PM
papo020
Jul 17, 2015 10:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
