VDC + Brake + Slip lights ONLY when it's cold.
Old May 14, 2014 | 01:26 PM
Marioh's Avatar
Checked the brake fluid and it's fine. What would cause these lights to come on? Hard to test now, but basically when I was in the mountains or it snows in Denver, the lights turn on. Occasionally the brake like doesn't come on and it's only the VDC + Slip. Anywho... any advice? Going to be hard to check this summer but figure if there's any simple answers to keep in mind that'd be great. Thanks!
Old May 14, 2014 | 03:37 PM
Mustang5L5's Avatar
Does it have anything to do with moisture, or freezing temps?
If you find the light comes on under freezing, i would suspect water has gotten somewhere where it shouldn't and when it freezes, causes issues.
My suspect would be the ABS sensors and wiring. That's where I would check.
Unsure if this would be of any use to you
http://www.nicoclub.com/FSM/G35/Seda..._Sedan/brc.pdf
Old May 14, 2014 | 03:52 PM
Marioh's Avatar
You know, it very well could be a moisture issue. It might have done it when it was raining (cold rain, in the 30's and transitioning to snow).
I'll look through the factory manual and maybe take a quick visual peak at the ABS pump/sensors/wiring. Thanks for the direction on that!
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
