Vibrating wheel
Old May 18, 2014 | 06:58 PM
OnlyGoWOT's Avatar
Vibrating wheel
Hi guys. I found that on the highway my wheel vibrates side to side a bit. Nothing extreme and it does not make the car feel unstable. Car does not seem to pull but it's hard to tell since the highways around here are banked. It does not pull at lower speeds. It only vibrates from around 54mph+. It does not even out any speed up to 70mph that I have seen. I do know that a tire that was on the rear before winter is now on the front after I took the winter tires off. I don't know if this would cause anything, just trying to add information that might be found relevant. 2004 G35x 61k miles.
Old May 18, 2014 | 10:40 PM
Urbanengineer's Avatar
Wheels need to be rebalanced. Alignment should be checked.
Old May 19, 2014 | 01:25 AM
hurleyguys's Avatar
also check your tires. worn tire can act funny
obender66
18 Inch
Mar 13, 2016 12:20 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
Frostbite91
Aug 20, 2015 07:20 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
