MD 5/16 Plenum Spacer
Old Dec 26, 2014 | 03:09 PM
ImJJames's Avatar
$180 on amazon
Amazon.com: MOTORDYNE BASIC 5/16 INCH PLENUM SPACER FX35 350Z G35 M35: Automotive Amazon.com: MOTORDYNE BASIC 5/16 INCH PLENUM SPACER FX35 350Z G35 M35: Automotive
I am about to purchase it, just making sure this is legit. Because it seems really cheap compared to other sites.
EDIT:
Installed them today took about 30 minutes. Had one minor issue, suppose to use in/lb torque wrench but instead I used ft/lb torque wrench and just divided the feet to inch. First time I started the car the engine had a rough idle every 5 seconds or so. In the end I found the issue, the plenum bolts were still not tight enough. So I gave it a few more turns on each bolt and voila everything is working perfectly.
Old Dec 26, 2014 | 04:35 PM
JHereth22's Avatar
Just get one from Z1. Z1 plenum spacer. Better product
Old Dec 26, 2014 | 04:45 PM
JHereth22's Avatar
http://www.z1motorsports.com/350_g35...oducts_id=2854
Old Dec 26, 2014 | 04:51 PM
ImJJames's Avatar
How is it exactly better?
Old Dec 26, 2014 | 04:53 PM
JHereth22's Avatar
Your just getting a basic spacer, same as this. Except this is cheaper.
Also I've purchased 2 of these, for different cars and have never been disappointed
Old Dec 26, 2014 | 05:16 PM
ImJJames's Avatar
Thanks, the link you gave me doesn't tell me if its 5/16
Old Dec 26, 2014 | 05:20 PM
JHereth22's Avatar
I assume it is man
Old Dec 26, 2014 | 05:35 PM
ray1370's Avatar
Originally Posted by ImJJames
$180 on amazon Amazon.com: MOTORDYNE BASIC 5/16 INCH PLENUM SPACER FX35 350Z G35 M35: Automotive
From the link on Amazon it's sold by OC Infiniti, which is a sponsor here, so it's legit. And so is Z1. Either one should work for you.
Old Dec 26, 2014 | 05:38 PM
JHereth22's Avatar
But Z1 is the S%IT!
Old Dec 26, 2014 | 05:53 PM
ImJJames's Avatar
Just realized OC infiniti is around 15 minutes away, going to pick it up right now
Everyone is saying how they can feel the difference with butt-dyno, hopefully I will too.
Old Dec 26, 2014 | 06:32 PM
ray1370's Avatar
Don't forget to mention you're a member on here. Happy shopping!
Old Dec 27, 2014 | 12:48 AM
Gman56's Avatar
5\16 is the size you want. 1\2 not as good as 5\16. I f you live in a warm climate you dont need throttle body heater.
Old Dec 27, 2014 | 06:08 PM
ImJJames's Avatar
Updated OP
Old Dec 27, 2014 | 07:15 PM
ray1370's Avatar
Looks good, now go feel the difference with your butt-dyno!
Old Dec 31, 2014 | 05:06 PM
ImJJames's Avatar
Been flooring this car for the pass few days, I can definitely feel difference in low-mid RPM range.
Side note, why does every car feel like they want to race me?
