2004 g35x white? smoke out of exhuast
Old Jan 21, 2015 | 09:00 PM
egrick2013's Avatar
So I have a 04 g35x and i have noticed that I have been smoking out of my exhaust a decent amount. I cant tell if its a light blue or white smoke from my mirror but i have check the oil and it is clean and I am not losing any coolant. Do you guys have any idea what might be causing the smoke? I understand is could be my engine is consuming oil but is there a fix for it? I also got a new PCV valve because i think i saw somewhere saying that if its bad it could cause this type of problem. Any help/input will be greatly appreciated.
Old Jan 22, 2015 | 04:00 PM
Nick_d_G35x's Avatar
Could just be condensation burning off from the catalyst doing its job.
Does it do it all the time or just in the mornings or after it's been sitting for a while? Is it cold where you are?
Old Jan 22, 2015 | 04:11 PM
egrick2013's Avatar
Its seems to do it all the time. I've considered it just being steam but I doubt it. It is cold up here I live near Philadelphia, pa so its around 35 degrees here.
Old Jan 26, 2015 | 11:27 AM
Mustang5L5's Avatar
Well, in the winter that's a different story. Are other cars around you doing the same thing? A lot of cars smoke from the exhaust when it's cold out. Mine was doing it today, but it's 15 degrees out.
Take a look around and see if other cars are smoking the same amount as you are. If so, then it's probably a combination of the H2O present inthe exhaust and the cold air.
Old Feb 23, 2015 | 08:49 AM
jb_g35x's Avatar
Most cars in the snow at least here in NY have vapors coming out of the exhaust because of the frigid weather, I would not be concerned about it. If you are burning oil you can simply test by looking at your dipstick to see the levels. Only thing is its a huge PITA to put the dipstick back for some reason
Terry_G35
May 9, 2020 01:39 AM
itztwinki3
Lights
Oct 15, 2015 04:38 AM
JermaineSanders
Aug 18, 2015 08:57 PM
Jroc2017
Aug 12, 2015 11:21 AM
Terry_G35
Aug 4, 2015 02:38 PM
