2004 G35x Radiator Fan wont turn off
Old Feb 17, 2015 | 10:43 PM
PetersG35x's Avatar
Unhappy 2004 G35x Radiator Fan wont turn off
Hey guys, I bought this car about a year ago with 108k on it and it works fine, the only problem is after i changed the coolant from the car, the radiator fan wont stop, I bleeded out the coolant system already, heater and AC works fine but for some reason the fan turns on and doesnt stop, I looked through threads already but i cant seem to find the answer. Please help me out! Thank you
Old Feb 18, 2015 | 08:11 AM
Mustang5L5's Avatar
Do you have a scanner that you can hook up and display live data? I'm curious to what your coolant temp is now?
Trying to determine if fan is on due to electrical fault, or on due to your engine running hot and needing it
Old Feb 18, 2015 | 10:01 AM
PetersG35x's Avatar
No I do not, My coolant temp is fine and it sits below the middle on the gauge, when i drive for around 5-10 min it kicks in for no reason
Old Feb 18, 2015 | 10:41 AM
Mustang5L5's Avatar
The dash gauge is more of an idiot light and not very accurate in terms of deciphering actual engine temp.
If you changed coolant, and now the fan comes on and won't turn off, i would suspect high engine temps, but would need to hook up a scanner to confirm.
Old Feb 18, 2015 | 09:24 PM
PetersG35x's Avatar
Will take it to a auto shop to scan it, I'll keep updates.
KevinnnVo
Oct 14, 2024 04:33 PM
JermaineSanders
Aug 18, 2015 08:57 PM
Jroc2017
Aug 12, 2015 11:21 AM
yassy
Aug 3, 2015 12:24 AM
joedaddy1
Jul 28, 2015 02:58 PM
