Another mod/performance question...
Old Mar 8, 2015 | 01:54 PM
CV35Driver's Avatar
True on the spacer.
Question is,
What is the big difference between the 1/2 and the 5/16?
I think, the 1/2 gives more towards the high end? Where as the 5/16 is more balanced?
Dont have an exact answer as to what it is.
Old Mar 8, 2015 | 06:37 PM
Urbanengineer's Avatar
Originally Posted by CV35Driver
True on the spacer. Question is, What is the big difference between the 1/2 and the 5/16? I think, the 1/2 gives more towards the high end? Where as the 5/16 is more balanced? Dont have an exact answer as to what it is.
They are effectively the same as there is a less than 10% difference between them! But 5/16 for price and DAily DRiving.
Old Mar 8, 2015 | 11:13 PM
markc's Avatar
Go to Motordyne's site and read up on it. All the info and stats you need are there including dyno runs.
Old Mar 10, 2015 | 10:49 AM
drkjed's Avatar
Ok so this kinds fits in the thread... well sorta... So I swapped out the Cabin filter WOW was that one NASTY. It was not too bad to install but still a high pucker factor when popping off trim panels lo. The AC and other climate functions actually work better go figure.l. I also swapped the generic air filter with a Purolator PureONE. and seemed to picked up a little bump in mpg... woohoo win win! SO one the stupid heat shields on the Ypipe was rattling so I fixed that. While under the car and looking around I got a good up close look at the sedan mid....HOLY CRAP that thing is HUDGE! I knew it was big from some photos but OMG that's crazy...looks like it must weigh 50lbs or something. It is also starting to get flange cancer at the Y but the y itself and rest of the flanges look great. So what's the best option for a 35X pick up just a resonator and have a shop make the rest? or get a full new OE replacement mid such as a Walker or a used coupe pipe? is a used mid asking for trouble in longevity ?
BlueBelleG35x
Jul 23, 2015 02:10 PM
Triji
May 31, 2007 11:57 PM
Clean G 4D
Intake & Exhaust
91
Nov 26, 2006 12:00 AM
Railgunner
Nov 10, 2006 09:11 AM
waterp7
Nov 6, 2006 06:44 PM
