Need help with front sway bar links!!
Old Mar 6, 2015 | 12:27 AM
hinduman g35X's Avatar
I have my front sway bar down and Im replacing my front sway bar links I got from Rock Auto, well where the sway bar link bolts on to the control arm it looks like it doesn't come off because it is connected like a ball joint?? I took off the 2 bolt on the opposite side of control arm a it looks like 1 sold unit. All I got from Rock Auto was the sway bar endlink and the 1 nut that holds it on. Any help would be great.
Old Mar 6, 2015 | 12:44 AM
hurleyguys's Avatar
i changed mine years ago. i cant remember what it looks like but i know it was straight forward. i forget if you have to use an allen wrench on it or if their are notches near the ball joint.
Old Mar 6, 2015 | 02:05 AM
I know I thought the same thing super easy job...straight forward but where the bolt comes out of the lower control arm it seems as it is one piece connected with the ball joint. Is it different because it is the X model?
Old Mar 6, 2015 | 08:28 AM
Mustang5L5's Avatar
http://www.nicoclub.com/FSM/G35/Seda..._Sedan/fsu.pdf
Page 26
The AWD end link is different from RWD. The AWD style is more like a balljoint. The two bolts on the backside remove the balljoint, but to remove the end link, there should be a nut on the front side.
If you want to replace that ball joint
http://www.infinitipartsusa.com/2006...546-124037.htm
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
wuppiedog
Aug 7, 2015 11:16 AM
atk08
Jul 30, 2015 03:12 PM
