Is this right?
Old Mar 8, 2015 | 03:06 PM
Fiyyaa's Avatar
Is this right?
Hey guys, i just bought these used XXR 527 rims from a private seller, and when i tried them on they stuck out quite a lot, and im a bit worried. 1st off does this look stupid? 2nd can it cause problems? Because most cars i see the wheels are flush. Any help would be appreciated, thanks!
Old Mar 8, 2015 | 04:54 PM
eazdaskeez's Avatar
Post a picture
Old Mar 8, 2015 | 04:55 PM
Fiyyaa's Avatar
Originally Posted by eazdaskeez
Post a picture
i will when i get them on, its still pretty crappy weather right now and im not sure if the salt on the road will ruin the rims
Old Mar 8, 2015 | 06:26 PM
Urbanengineer's Avatar
Yes when it sticks out it means the offset is bad or your bore size does not match (it may not be sitting correctly!). If it is a wide wheel with low offsets (less then +10) then you will have issues fitting these at all .
Old Mar 8, 2015 | 06:28 PM
Fiyyaa's Avatar
I tried them on and they fit okay, or are you talking about something else. Do you suggest I re sell them?
Old Mar 8, 2015 | 07:38 PM
On the back of the wheel it will list the wheel size (18x8), offset (+33), and bore (66.1mm I think for Infiniti). What does yours say.
Old Mar 8, 2015 | 07:48 PM
Fiyyaa's Avatar
I know the xxr size is 18x9.75. I would have to check the offset
Old Mar 8, 2015 | 07:49 PM
Fiyyaa's Avatar
Sorry I'm not very specific I'm pretty new, thank you for replying btw
Old Mar 9, 2015 | 08:14 PM
Mustang5L5's Avatar
Is your car lowered? The risk is if you hit a good bump, the tire can rise and hit the fender lip. What happens then is anyones guess. I've seen cars with rolled lips slice the tires. I've seen the tire put good dents in the fenders.
But regardless...this does not really look that great.
Old Mar 9, 2015 | 08:15 PM
Fiyyaa's Avatar
damn :/ i might have to sell them :/
Old Mar 9, 2015 | 08:19 PM
Mustang5L5's Avatar
I also forgot to mention that technically, the tires must be covered by a fender to avoid flinging rocks and road debris. You'll notice that when a lot of jacked up 4X4 trucks put big tires on, they also add fender flares to help meet that regulation of having a fender cover the tire completely.
I know nobody on this forum gives a rats *** about regulations anyway since half the mods done to cars here are illegal anyway.
Old Mar 9, 2015 | 08:20 PM
Fiyyaa's Avatar
so even if i did keep the wheels its illegal?
Old Mar 10, 2015 | 01:36 AM
I also forgot to mention that technically, the tires must be covered by a fender to avoid flinging rocks and road debris. You'll notice that when a lot of jacked up 4X4 trucks put big tires on, they also add fender flares to help meet that regulation of having a fender cover the tire completely. I know nobody on this forum gives a rats *** about regulations anyway since half the mods done to cars here are illegal anyway.
Oh grandpa
It isn't necessarily illegal, it just doesn't look good. Get the numbers (one from front one from rear).
Old Mar 10, 2015 | 09:35 AM
Mustang5L5's Avatar
Depends on where you live.
Quick 5 min search, but here is the law in Oregon stating the fender must cover the tire.
http://www.oregonlaws.org/ors/815.180
The width of any fender or mudguard required under this section must be of sufficient size so that the fender or mudguard extends at least to each side of the width of the tire
It might be an inspection issue thing if whoever inspects your car follows the letter of the law
Old Mar 10, 2015 | 09:20 PM
Fiyyaa's Avatar
this is what it looks like. and now that i have them on, when i drive i hear a washing machine noise coming from the rear right tire.. any ideas? :/
