5at rpm drop?
Old Mar 17, 2015 | 12:32 AM
smokey2's Avatar
5at rpm drop?
03 5at....when cruising normal in auto, if i let off the gas the rpms drop down to 1k, then when i give it more gas rpms go up like normal and off i go. But at highger speeds like 60+ it seems like the rpsm will stay steady 1800, or 2000 or what not. is this normal on these transmissions is it going into to neutral or something?
Old Mar 17, 2015 | 01:44 AM
Urbanengineer's Avatar
Gear ratios are different for each car and at high speed your car is maximizing its operation (constant power) vs low rpm at low speed it coasts.
Old Mar 17, 2015 | 01:45 AM
smokey2's Avatar
So it is normal for the rpms to drop down to 1k really fast when i let off the gas going like 30-40
Old Mar 17, 2015 | 09:45 AM
Mustang5L5's Avatar
That's what a torque converter does.
They are designed to lockup under certain situations, and not lock under other situations. What you are describing is normal. At lower speeds, the converter is not locked, so when you let off the gas, the Engine RPM drops. At higher speeds/RPM, the converter locks and acts like a clutch being directly coupled to the transmission. It's also (mostly) locked during manumatic mode, although sometimes it's a little "loose".
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
vamarris
Sep 26, 2015 12:56 PM
