Aftermarket bushings for the AWD
Old Mar 18, 2015 | 11:16 PM
Skeeter SS's Avatar
I'm still looking to replace some parts on my car. Anyone install aftermarket lower control arm bushings on the X model? I see again Nissan/infinti does not offer a bushing but the whole arm. I see companies offering them for coupes and rwd sedans but didn't see any for ours.
I read the energy ones will work with some finessing so if anyone's installed them did they work?
Old Mar 25, 2015 | 07:10 PM
Skeeter SS's Avatar
No one has ever replaced bushings in lower control arm? Oh well guess I'll find out the hard way.
Old Mar 25, 2015 | 07:54 PM
yosip1115's Avatar
Ooor you could search. I literally just talked to someone about this the other day on the forum. I'll leave it up to you to see if it worked for me...
Old Mar 26, 2015 | 07:24 PM
medianjoe's Avatar
I installed whiteline busing some years ago. It still hold well. My car is RWD though.
Old Mar 27, 2015 | 11:12 AM
Mustang5L5's Avatar
Originally Posted by medianjoe
I installed whittling busing some years ago. It still hold well. My car is RWD though.
That's good to know but doesn't really help the OP?
Old Mar 31, 2015 | 11:59 AM
Skeeter SS's Avatar
Thanks but someone else was able to provide an answer. Thanks for posting your knowledge on the subject.
Old Mar 31, 2015 | 12:10 PM
yosip1115's Avatar
Add it to the list of useless forums to thumb through when finding info...
Old Apr 3, 2015 | 10:27 PM
munkle's Avatar
Here are the parts you're needing, most likely. https://g35driver.com/forums/g35-sed...trol-arms.html
So, this thread is really about replacement parts for the AWD front end suspension, which is a PITA to deal with. There's not a lot of information. I went through this same gauntlet several weeks back, and even posted a thread as well. In short, I found a manufacturer who supplies both the compression rods and the lower control arm (forward) for the 03-06 G35X, with all OEM-style bushings and joints in place. Best part is that all four items only cost a little over $300.
Us AWD drivers need to help each other out. For anyone here looking for the answer, check my first post in this thread (https://g35driver.com/forums/g35-sed...trol-arms.html) from a few months ago. The four parts linked in my OP were ordered, installed by me (in addition to new struts), and work flawlessy. My 183K mile 2006 X is now very smooth and quiet up to at least 100 mph.
EDIT: The link provided in my post from the other thread will likely lead you to CARID.COM, and to a page which says "out of stock". Just copy the part number and do a Google on those part numbers, and somebody else will have them. Also, O'Reilly's now sells parts for the AWD suspension, at a a 50% premium to the CARID.COM prices you'll see on those links form the other post. I think their part numbers even align with Mevotech's, although O'Reilly's has branded them "Import Direct" or some crap like that. I think they're identical to the Mevotech parts, anyway.
Old Apr 10, 2015 | 09:08 AM
Skeeter SS's Avatar
In the future if I need some arms I will purchase the mevotechs. Mine are still holding up but since I was changing out the tie rod ends is figure I'd look at the lca bushings. I wanted some firmer ones but really couldn't find any awd guys that had installed them.
Old May 20, 2015 | 02:49 PM
OKStateG35's Avatar
I'm replacing bushings in the front lower control arms, upper control arm and compression rods this weekend. Whiteline all around. From the research I've done, all bushings are compatable between RWD and AWD except for the front strut mount (outer lower control arm). I believe the metal bolt sleeve is just slightly too small for the bolt to fit through, but the bushing itself should fit. I plan to either drill out the bushing and use the OEM bolt sleeve or drill out the Whiteline sleeve to fit the bolt. I will update once complete.
I'm also replacing front struts, strut mounts, inner and outer tie rods, rubber brake lines, hubs, bearings, rotors, pads and tires. Hoping the old X will feel like new next week.
Old Feb 15, 2017 | 12:30 PM
smasherclaus's Avatar
Update
hey, do you have an update on this? I'm looking to get the energy suspension bushings for my g35x.
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
Danielek
May 1, 2022 01:28 PM
Blue Dream
Dec 5, 2015 10:56 AM
alessandro
Oct 8, 2015 09:29 AM
