New to the G35 community and need HELP
Old Mar 31, 2015 | 09:14 PM
markc's Avatar
I pointed this out several posts ago. The big news is that when he shifts from auto to manual it stays in auto. Trans electrical problem I would suspect.
Old Mar 31, 2015 | 10:42 PM
maxxcool's Avatar
Yup wife had a beetle that did this. For the bug it was a fuse. OP.. sorry bub. you will need to visit a dealership or be really awesome with a multimeter and schematics.
Old Apr 1, 2015 | 12:00 AM
G2B35AGN's Avatar
Originally Posted by Mustang5L5
Again, with my X and it's 3.5 FD....
80MPH in 5th gear is ~ 3000 RPM
60MPH in 5th gear is 2100 RPM
60MPH in 4th gear is ~ 3000 RPM
I'd image with the 3.3 FD, the RPM's would be a tad lower.
I'm going to have to check my '06x tomorrow. My memory says at around 80 MPH I'm twisting about 3200 RPM.
Old Apr 1, 2015 | 09:04 AM
Mustang5L5's Avatar
OP....any lights on in the dash? check engine?
Old Apr 1, 2015 | 12:39 PM
gioxes's Avatar
it stay on 4th
Old Apr 1, 2015 | 01:53 PM
maxxcool's Avatar
the rocker switch is gone. if it drops a gear and actually goes into manual mode but won't shift up or down it's the switch.
Old Apr 1, 2015 | 03:50 PM
Mustang5L5's Avatar
Originally Posted by gioxes
it stay on 4th
No offense, but we are going to need a lot more info here.
It stays in 4th....when? What are you doing?
Old Apr 2, 2015 | 07:41 PM
gioxes's Avatar
I got the code p0720 for the output speed sensor, what u think about that, it is possible it skip the 5th gear?
Old Apr 3, 2015 | 10:50 AM
maxxcool's Avatar
Not allowing a upshift would be new to me. But not out of the realm of possibility. either way if it is the speed sensor with the spinny bit you should replace that sooner than later as it will cause excessive wear on the tranny.
Old Apr 22, 2015 | 11:21 PM
G2B35AGN's Avatar
I need to quit putt-putting around town and get out on the highway more often (and improve my memory to do things when the opportunity presents itself). April 1 was not yesterday....
Finally had a chance to check this out today. For me in the '06x 5AT sedan, it is 3,000 rpm @ 75mph and 3,200rpm @ 80 mph. Stock wheel setup.
Old Apr 23, 2015 | 05:15 PM
Mustang5L5's Avatar
I would say that that could have an impact considering it tells the ECU the vehicle speed and probably is in input to transmission shift logic.
I'd replace this ASAP
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
