sputtering when fans kick on
Apr 4, 2015 | 11:55 PM
for some reason i noticed when my fans kick on my idle drops really low. it sometimes sputters like its going to shut off and i think runs lean i could hear the exhaust popping a little. one time a cel came on saying cylinder 1 was lean. only happened once the cel, bout usually when fans kick it almost feels like its ready to shut off. anyone have similar issues? or anything?
Reply 0
Apr 6, 2015 | 04:42 PM
anyone? im pretty sure couple people have this issue
Reply 0
Apr 8, 2015 | 12:17 AM
bump.....it also bogs in 2nd hittin 3.5k when fully floored
Reply 0
Apr 8, 2015 | 10:46 AM
Water pump dying?
Reply 0
Apr 9, 2015 | 09:20 AM
High electrical load due to failing fan? Or weak alt/battery?
Can you put a digital multimeter on the battery and check to see that there isn't a big voltage drop when the fans kick on? At idle should be 12-13V or so, but if the voltage drops to 9-11V when the fans kick on, the engine may have trouble running.
Reply 0
Apr 9, 2015 | 03:26 PM
Sounds like a bad ground. but that will be a severe pain to diagnose.
(1) to your flavor of the region battery shop. test your battery and charging rate.
(2) failing that buck up and pay the 100$ for a stealership diagnosis if you are anything less than a wizard with ohm meters and a schematic.
Reply 0
Apr 16, 2015 | 11:40 PM
Quote: Water pump dying?
what other diagnosis for water pump...i just changed the battery thinking it was that as well
Reply 0
Apr 16, 2015 | 11:41 PM
Quote: High electrical load due to failing fan? Or weak alt/battery?
if the voltage gets that low would could it be?
Reply 0
Apr 17, 2015 | 09:26 AM
Weak battery, weak alternator, bad grounds, shorted power lead, bad battery cables, etc etc.
Basically from your post, i'm concluding that there is a power drain somewhere that causes the engine to not have enough power to run properly. I've seen this happen before with some of the above causes.
Reply 0
Nov 2, 2015 | 03:24 PM
Quote: Weak battery, weak alternator, bad grounds, shorted power lead, bad battery cables, etc etc.
ya im prob gonna check on alternator...its a new battery...added a grounding kit from gordgee
Reply 0
