Rear axle click is back
Old May 27, 2015 | 12:47 PM
RADIOGUY21's Avatar
I had the TSB done years ago, but the clicking noise is back. Every time I reverse and shift to drive I'll get a click click noise coming from the rear drivers side. I'll hear it from time to time when coasting.
At 130K miles, what needs to be done to the rear axles? Replacement? I've had both rear wheel bearings replaced and diff fluid changes, but nothing with the axles. Do they just need to be greased up again?
Old May 27, 2015 | 01:07 PM
Mustang5L5's Avatar
Man, talk about a blast from the past. I haven't seen the words "rear axle click" posted on these forums in 5-6 years or so.
I had that TSB done on my car when it had 25K miles or so. 160K and it's been good. If I were in your shoes, i'd just be thinking that it's time to reapply the grease and hope that takes care of the issue.
Old May 27, 2015 | 01:09 PM
LoSt180's Avatar
Plus 1 on re-greasing them up. Since you've had wheel bearing replaced, it's probably safe to assume the grease wasn't applied to the new bearings.
Old May 27, 2015 | 05:17 PM
RADIOGUY21's Avatar
Yeah for such a common problem early on, I was surprised with no recent threads when searching. Perhaps most people here took care of it under warranty.
I was also thinking my mechanic didn't grease them enough when the bearings were changed. Had that done about a year ago.
Old May 27, 2015 | 10:31 PM
5150DS's Avatar
Mine started at around 60-80k. Never fixed it and have over 200k. Either it went away or I dont notice it anymore.
Old May 28, 2015 | 01:48 AM
christopherv5's Avatar
I have the info on what I got replaced. I'll post up tomorrow morning on what exactly it was, have to find the paper work
rezendvous420
May 31, 2020 01:26 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
apintojr
Jul 23, 2015 10:52 AM
