Can't read the dipstick
Old Jul 6, 2015 | 07:38 PM
EasySausage's Avatar
What TF is wrong with this thing? I'm not sure how my car is with oil so I'm trying to check it like twice a week or so to see how much oil it burns but I can never get a good read..ever. It looks like the oil stops right at the low sign on the stock but when you turn it over it goes all the way up the stick? How do you guys get past this thing and figure out what your oil levels actually are?? Please help I wanna stop worrying about my oil levels hahah
Old Jul 6, 2015 | 08:59 PM
herrschaft's Avatar
Let the car sit for 20/30 minutes after engine is off than check.
Old Jul 6, 2015 | 09:20 PM
Yeah that's what I do. I tried 2hr after it sat, and also like around 20hr after it sat. Every time it's the same annoying thing it never reads good. When do you think is the right time frame to do it?
Old Jul 6, 2015 | 09:26 PM
herrschaft's Avatar
Time of day doesn't matter. Do you wipe the stick off first before putting it back in to check the level? 2 hours is more than enough for the oil to drain back to the pan so you should be able to get a consistent reading.
Old Jul 6, 2015 | 09:27 PM
markc's Avatar
Leave it sit over night and check it the morning. Look at the side the gauge is on and believe. What else can you do? I have 2 VQ35DE's and neither one is a problem to read. The oil level is the same on both sides of the stick. Pull it out, wipe it off, reinsert, pull it out and read.
Old Jul 6, 2015 | 09:35 PM
Yeah I take it out wipe it off stick it back in and then take it out to read. I have to do this about 3-4 times and every single time to reading is never consistent. It's always like halfway up the dipstick on one side lmao. maybe I should try and get somebody to do it for me it seems like I'm the only one that's having a problem with one of the simplest things
Old Jul 6, 2015 | 09:36 PM
Alright I'm going to try tomorrow morning. If it does the same thing I'll post a pic and show you guys what I'm taking about. It's so annoying
Old Jul 6, 2015 | 10:15 PM
saywat?'s Avatar
its easier to jus check it in the morning before u start ur day
Old Jul 6, 2015 | 11:53 PM
EWT6MT's Avatar
Like others have said, just try first thing in the morning after the car has sat.
Before my '05 G35, had an '02 Maxima. Always had the same issues...couldn't get a decent reading unless I checked first thing in the morning.
Old Jul 7, 2015 | 12:16 AM
saywat?'s Avatar
Ull get used to it. Ima pro at reading the dipstick
Old Jul 7, 2015 | 12:40 AM
gary c's Avatar
Welcome to Auto 101, don't fathers teach their sons anything in today's world? After you've waited for the oil to drain back down while checking your dip stick you may need to turn it over to find the line, my stick is one sided!
Gary
Old Jul 7, 2015 | 01:36 PM
Mustang5L5's Avatar
I agree with everything else said here. Park the car on a level spot, go have lunch or dinner for 2-3 hours. Come back. pull the stick, wipe it, and reinsert and then take a reading.
I find that if the oil level is at the very bottom of the hash zone, i'm 1 qt low
Old Jul 7, 2015 | 01:48 PM
WhosUrBuddiee's Avatar
This thread made me laugh and sad at the same time.
Old Jul 10, 2015 | 03:16 PM
ranhood's Avatar
I hear ya EZ. the oil dip setup on these is screwy!! I do have to let mine sit longer than any other car/truck i've owned. I also insert my dipstick =) both directions - as in - with the stamped lettering facing toward grill and then again facing toward firewall. It varies. I also have learned that when it's low on oil... get the oil on the side of dipstick you mentioned. I put a quart in and then get consistent readings! Lettucekno how it goes.
Old Jul 10, 2015 | 03:17 PM
saywat?'s Avatar
ugh isnt the stick pre-formed to go in a specific way other wise ur jus forcing it and bending it?
