03 Sedan, Help with Starting Problem
Old Jun 5, 2017 | 02:29 AM
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by chinee
It was simply a bad starter. After driving for a few miles, the starter would get too hot to operate. After cooling down for several hours the car would start again without a hitch. Switched out the starter and there's been no problem since.
Originally Posted by Ervin Ramirez
the idiot who installed my sound system messed up on the grounding job. The battery light and endless surfing of forums was a nightmare. Took it to a pro audio shop and got everything re-wired, and tada all better. I definitely agree with the ground theory.
That wasn't his problem obviously as he stated above.
Originally Posted by cpcook
Been frustrating as having the same identical problem. Two mechanics told me starter was not the issue. Can you confirm that the starter fixed your intermittent starting issue?
He already did in his post above lol.
Old Sep 29, 2020 | 11:48 AM
Sam Samson's Avatar
g35 coupe
Red face
Update...
4 hours later, and I go to pick up the G. It starts up on the first try!.
The first whirr from the starter sounded a little weak, and then returned to a normal starting sounded, then ignotion. I'm beginning to suspect that the battery may be the culprit, and will get it tested again.
In the meanwhile, I will still welcome any comments or ideas from fellow G35Drivers!
Hello,
Sounds like a grounding wire. check your wiring harness inside the engine bay. Hope it all works out for you.
Old Apr 19, 2021 | 08:55 PM
Soular's Avatar
Stock
Error post. Moved to the proper thread. Sorry
Old Apr 19, 2021 | 09:09 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Looks like you "infiniscrolled" into another thread, this one is talking about problems with getting a car to start, not about wheels.
Old Apr 19, 2021 | 09:15 PM
Soular's Avatar
Stock
Brakes
Damn Sorry about that!
EDIT: If you don't like the infiniscroll option it can be disabled under your Settings & Options > Edit Options > near the bottom under Thread Display Options > Infinite Scroll
Old Apr 19, 2021 | 09:18 PM
cleric670's Avatar
BANNED!!!
No worries, catches a lot of folks.
Old Jun 10, 2024 | 07:48 PM
Ccdmn85's Avatar
2006 g35 coupe, 6mt exhaust, headers, body kit , cherry red paint, pedal commander, plenum spacer
Same issue in my g35 sedan
TUrned out to be the camshaft position sensors. Replaced em, and never had the problem again.
Hi there... it's been a long time since I've been a regular visitor to the forum, but I'm glad to see that there's still activity! I am reaching out for help and ideas to resolve a fairly recent starting problem I've been experiencing. To provide a comprehensive view of the issue, I'm going to go into detail, please bear with me...
About 6 months ago, in the middle of the day, the car wouldn't start right up. The starter engaged but sounded like it was spinning almost freely without much load, but the car would not start. After a few tries the car started normally and I was on my way. Since then, this has happened about twice a month, but since it always started, I didn't worry too much. It is after all a 12 year old car with 195,000 miles.
About 3 months ago, even though the battery was just a year old, I still went in to AutoZone for them to test it. It's still good and they tested the charging/starting system and everything checked out. So I bought a new starter, and only just installed it last month. But I'm still getting the false start every couple of weeks or so.
This past Thursday, ran out into the car during rain, and the car gave me the same false start, this time it kept cranking but not starting. So I played with turning the key at different intervals and different durations. After two quick twists on the key, so the stater engaged, disengaged and engaged again, all in less than a second, the car quit cranking. Sounded like a dead battery, or something more serious. "Damn!"
Called AAA, battery tested good, but still no cranking. Called for a tow truck. While waiting, tried to crank every 10-20 minutes so see if I could get a start going. Still sounded like a dead battery. After a 3 hour wait, the tow truck came, and I suggested that we try a jumpstart before he actually hooked me up... no problem... while I was getting the cables ready, the driver asked if he could turn on the ignition to see what lights were showing on the dashboard. And what do you know... the G started right up.
After a 40 minute drive home, I shut the car off, and it would not start again. Slow dead battery cranking sounded. After an hour, I tried again and it started up.
Friday... I did not go anywhere but did start the G to move it out of the garage into the driveway. Left it there for a few hours, then back in the garage. Each time I started it and turned it off, and back on again several times to see if maybe the battery was draining quickly. No problem.
Saturday (today) drove to Autozone to pick up sparkplugs, although I currently have NGK Iridiums installed 15 months and 25K miles ago, I figured it couldn't hurt to change them again. Started fine. Stopped at the grocery on the way home, spent about 30 minutes inside. Come back out and... no start... dead battery slow crank. Got a lift home for my Sequoia and brought my multimeter. Battery at 12.55v, after a few tries at cranking again (slow dead battery sounds), the battery is down to 12.2v. So it doesn't seem to be the battery right? Left the G there and will go back in a few hours to try to start again and attempt with jumper cables as well.
Any ideas anyone?
- thought it might have been a problem with the anti-theft chip in my key, so I put my usual key on the rack, and started using my spare key that's looks new... no change.
- looked for codes from the computer, only a P1706 (park neutral switch) that's been on and off for the last 8 years without any outward issues.
- it was suggested that the camshaft position sensor and/or crankshaft position sensor might be the culprits. The car shutting off while driving seems to be a common symptom of this, but I don't get that.
At this point, I've not found any potential solutions from the numerous online searches I've conducted. And to bring the G to a garage for a problem that's as intermittent as this, just frustrates both me and the mechanic, not to mention my wallet.
I do not have a regular mechanic, since I do almost all maintenance myself, so do not know of a good G mechanic anywhere close to me.
If you've spent the last several minutes reading this post, I do appreciate the time you spent doing so. If you can provide the solution, or any ideas that I can try, I would be immensely grateful. Thanks in advance!
mpspeer
Mar 15, 2016 12:43 PM
mrley67
Oct 9, 2012 02:44 AM
yakswak
16
Dec 24, 2008 12:15 AM
Agent F
Oct 2, 2008 06:46 PM
jcs1957
Jan 7, 2007 11:41 PM
