06 G35X Sedan keeps blowing 40amp cooling fan fuse
Old Jul 31, 2015 | 07:39 AM
nettcar's Avatar
Hello, i have an 06 G35 that keeps blowing the 40 amp cooling fan fuse, causing the car to overheat. Does anyone know what may be causing this? Thanks
Old Aug 2, 2015 | 08:04 AM
yassy's Avatar
you need a new radiator cooling fan assembly. very simple to do.
heres one i bot on amazon.
Amazon.com: TYC 620980 Infiniti/Nissan Replacement Radiator/Condenser Cooling Fan Assembly: Automotive Amazon.com: TYC 620980 Infiniti/Nissan Replacement Radiator/Condenser Cooling Fan Assembly: Automotive
Old Aug 2, 2015 | 01:45 PM
nettcar's Avatar
Ok, thanks...ill give it a try and let you know what i get...
Old Aug 2, 2015 | 03:50 PM
wuzz-upp's Avatar
I agree with yassy it most likely is one of your motors gone bad, I like to confirm electrical faults whenever possible though. There are two 40A fuses in the system, fuse H and fuse I, are they both blowing? If you want to confirm that one of your motors is the cause of the blown fuse, isolate the motors by disconnecting them. With the motors disconnected if your fuse or fuses don't blow, you have confirmed the problem to be the motor and eliminated all the other components and wiring in the circuit as the cause of your problem. If the fuse or fuses still blow with the motors disconnected you need to continue troubleshooting. Good luck.
Old Aug 2, 2015 | 07:47 PM
nettcar's Avatar
Both fuse do blow...i notice that they blow faster once the A/C is operating...thats also when the problem 1st occurred once i adjusted the A/C unit...
Old Aug 2, 2015 | 08:07 PM
wuzz-upp's Avatar
They blow sooner with the A/C because the minute you turn the A/C on the fans are designed to kick on. Otherwise with the A/C off, the fans will kick on only when the engine reaches high temperature and requires cooling. What do you mean adjusted the A/C unit?
With that said, try what I told you in my earlier post. With two good fuses installed, disconnect the fans. There are two connectors by the fan assembly one for each fan. Start the car and turn the A/C on and see if the fuses blow. Keep in mind though that you have to monitor your coolant temperature gauge so that you don't let the engine overheat. If the fuses don't blow then I would agree with yassy that your fans are the problem.
Old Aug 25, 2024 | 11:59 PM
MyVQIsAPOS's Avatar
G35 Coupe K23
My fuse blew and now it formed a weird bubble on top.
I changed the whole L fuse and the other fuses work besides the 40amp one as it didn’t blow apart instead it formed a weird bubble shape on top and I don’t know how to approach this.
KevinnnVo
Oct 14, 2024 04:33 PM
champppy
Mar 31, 2020 12:25 PM
yassy
Aug 3, 2015 12:24 AM
joedaddy1
Jul 28, 2015 02:58 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
