will these tires and rims fit on my sedan or hit the front upper arm?
Old Aug 31, 2015 | 09:49 AM
Fire0nic3's Avatar
Hey guys
I have TSW Nurburgring wheels on my sedan currently on my 2006 G35x and they fit however i want to put new tires on them and have a question. Here are the specs:
19 x 8.5" +45 mm offset all around
Current Tire size: 235/35/19 all around
I am not lowered nor am I running spacers.
Now my current question is that I have 245/40/19 tires i want to put on those rims. I'm just wondering will they touch the upper arm if i put on those size of tires on the front? Or am i going to need to run spacers to clear the upper arm? I ask because it seems the 235/35/19 tires already look pretty close to the front upper control arm. Thanks!!
Old Aug 31, 2015 | 03:18 PM
Mustang5L5's Avatar
OEM 215/55/17 is 26.3" in outer diameter
235/35/19 are 25.5" in diameter so these are smaller than stock diameter
245/40/19 is 27.7" in diameter Those are pretty large being over an inch bigger than stock. You might have rubbing issues, especially if lowered.
235/40/19's would be perfect if you can get those.
Can you get a 245/3
rezendvous420
May 31, 2020 01:26 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:23 PM
netcbc
Jul 24, 2015 01:59 PM
