206k trans fluid change
Old Oct 25, 2015 | 09:16 AM
5150DS's Avatar
Just did a drain and fill at 206k+ miles on my 05 5at. 5 quarts came out. Fluid was still red and clear. Little to no wear materials. I have been using Castrol import multi-vehicle since before 100k, so it is good to go. I manual shift pretty regular in red light traffic and drive my car pretty hard.
Did an oil change too. 4 3/4 qts out at 5k mile change.
Did a bulb syringe exchange on my ps fluid. It is looking good too. I use Castrol dex/merc in there.
Ive veen using mmo for a few miles in the fuel. Seems to have quieted a few noises.
I need a brake fluid flush, but I pay for that.
On a side note, I use these buckets for at fluid change. Makes measuring what I take out a breeze. A guy on an Armada forum suggested it.
http://m.homedepot.com/p/HDX-10-qt-Natural-Multi-Mix-Container-3-Pack-210217/204303499
Old Oct 27, 2015 | 03:09 PM
Urbanengineer's Avatar
What's so hard about the brakes ?
Old Oct 27, 2015 | 10:12 PM
5150DS's Avatar
The last time I did brakes I couldnt get all the air out.
Old Oct 27, 2015 | 11:17 PM
yosip1115's Avatar
Use a syringe to suck out what you can from the reservoir then use the two person method to flush the lines. No air!
Old Oct 28, 2015 | 09:18 AM
5150DS's Avatar
Yeah im probably just going to get a Motive 107.
Old Oct 31, 2015 | 07:39 PM
G35CO's Avatar
When I change the trany fluid in my 03 Sedan it only takes 3 3/4.
Is the 05 is different or do I need to put 5?
Old Oct 31, 2015 | 08:21 PM
JOKER's Avatar
CLUB MODERATOR
good to know your transmission is working good after new fluid.
I got a case of Amsoil sitting in my garage and I've been dreading to change my fluid, but since your have no issues to report I think I'll go ahead and flush it.
Old Oct 31, 2015 | 08:23 PM
JOKER's Avatar
CLUB MODERATOR
You must have only drained the pan and not the entire fluid. I think our cars take close to 9qts of fluid total. 3 qts in the pan, few in the cooler and few in the TQ converter. So to do a complete flush you need to disconnect a return line to the radiator (trans fluid return line, not the coolant line), start the car and pump will flush the fluid out. You need to do it in 3 qt steps. Pump 3 qts out, pour 3 qts in. Repeat until fluid from return line comes out clean and purdy.
Old Oct 31, 2015 | 10:01 PM
5150DS's Avatar
Not sure, I only did the pan. My graduated bucket showed 5 qts. I usually get 4.5-5 out.
Old Oct 31, 2015 | 10:02 PM
5150DS's Avatar
I do mine every 20k or so.
Old Nov 1, 2015 | 01:29 PM
JOKER's Avatar
CLUB MODERATOR
why?
Old Nov 1, 2015 | 01:52 PM
5150DS's Avatar
why?
****. I figure if I do it every 20k at about every 60k I have 90%+ fluid exchange.
purdaddy
Engine - Exhaust
Nov 15, 2015 12:27 AM
dpierce33967
Drag
Oct 27, 2015 11:45 AM
BlackG2017
Oct 25, 2015 08:43 AM
Jason Koch
Oct 22, 2015 01:07 PM
vQFamily
Sep 30, 2015 01:17 PM
