Engine blowing smoke
Old Oct 27, 2015 | 05:10 PM
g3fyve's Avatar
I bought a g35 and unknowingly 4000 miles later the oil pan went empty and resulted in a rod knock. Replaced engine that has 80k miles and is blowing white smoke.
It's not noticeable really at idle, unless I start revving the engine to high rpms. It doesn't come out thick. At one point the smoke almost was darker.
Now the engine has been sitting in a junkyard for a while probably. My dad said the catalytic converters were very bad but he soaked them in bleach.
Also, I noticed a loss of coolant but I didn't see any coolant in the oil and the radiator doesn't bubble. It hasn't overheated and the engine doesn't lack power. when driving the car kind of smells like I'm behind a Mack truck or something.
Just trying to describe my issue the best I can. I don't see any smoke at all if I just drive normal but if I bring the car to high rpms smoke will come out, but not thick.
Does this sound like a head gasket issue, could it possibly be something else?
Old Oct 28, 2015 | 08:30 AM
Mustang5L5's Avatar
If you are losing coolant, I bet it's going into the cylinder and getting burned off. Do a compression check and see if all the cylinders are within 10% of each other
Old Oct 28, 2015 | 09:17 AM
LoSt180's Avatar
Compression check. Could also be something as simple as replacing the PCV valve. Those can cause smoke when revving with no load, or WOT pulls.
magnetism80
Feb 1, 2019 10:00 AM
Joe Gargano
Sep 18, 2015 11:17 AM
flytim3
Sep 5, 2015 01:23 PM
Jnm07
Sep 5, 2015 01:16 AM
UT G35
Sep 3, 2015 03:58 PM
