None of my Power WIndows work, HELP!!
Old Nov 2, 2015 | 10:20 AM
bryanr's Avatar
Unhappy None of my Power WIndows work, HELP!!
Everything worked fine in my sedan last night, this morning leaving work I tried to roll my driver's window down and it did not work. I checked the window lockout and it wasn't on, I checked the passenger door switch and the window went down about 4 inches but now won't work again.
None of the window switches are working in any of the doors, but the power locks are working.
I've checked every fuse in the box in the driver's side compartment and the ones under the hood, including the 40Amp, and they're all good.
I'm at a loss, any help or advice??
Old Nov 2, 2015 | 10:48 AM
bryanr's Avatar
Also tried the door key window trick, it rolled the passenger window all the way down and the driver's side about 1 inch...Still nothing works.
Old Nov 2, 2015 | 11:46 AM
ciraleon's Avatar
It happens to so many G's... Time to replace your window motors. Happened to me.
Old Nov 2, 2015 | 12:33 PM
bryanr's Avatar
I'm leaving the salvage yard now with all 4 window switch control panels and the drivers side window motor..see if this does anything
Old Nov 2, 2015 | 12:50 PM
bryanr's Avatar
And is it normal for all 4 to go out at once though?
Old Nov 2, 2015 | 02:48 PM
bryanr's Avatar
Well, after all that trouble and worry I pop off the drivers side switch control panel and it's somehow unplugged. Simply unplugged. Unbelievable. I got lucky but this just goes to show, keep it simple stupid. Should've checked all connections, not just fuses. Thanks
Old Nov 2, 2015 | 03:01 PM
ciraleon's Avatar
No. Not at all. I'd double check the fuse. On my coupe, passenger side went out and then a couple of months later the drivers. Never heard all of them going out at the same time before.
Sounds like something electrical for sure.
Old Aug 30, 2023 | 01:39 AM
Window no work's Avatar
I have a 2003 g35 sedan which
None of my windows or power sockets work in my 2003 g35
Hey man I have the same problem, where is the drivers side switch control panel?
Old Aug 30, 2023 | 10:25 AM
05_SkylineSedan's Avatar
20 Year Member
It's the switch panel in the driver's door with all the window controls. That unit also does some logic processing (it's one of our black boxes) so if it fails the whole system can fail. Doubtful it would come unplugged unless you've had it off recently. But the first thing to check (after fuses) is the wiring running through the rubber boot from door frame into the driver's door. Pull that boot to pop it out of either side and look for frayed or broken wires.
mbe32
Nov 12, 2015 06:50 PM
jonl573
Oct 14, 2015 09:53 PM
dpark0223
Oct 5, 2015 09:02 AM
mbe32
Oct 4, 2015 10:27 PM
