05 Sedan & Coupe front bumper question
Nov 6, 2015 | 04:55 PM
I was interested in adding driving/fog lights to my sedan. I saw a few light kits on ebay/net that replace the inserts on the coupe (lower front bumper) but not one for the sedan. The 05 sedan bumper and coupe look similar from what I can tell but I have not had a chance to compare to a coupe in my area. Has anyone found a "light kit" for the sedan (complete insert)?
Coupe fog light kit: http://www.ebay.com/itm/fit-INFINITI...pV58Yv&vxp=mtr
Reply 0
Nov 6, 2015 | 08:40 PM
Subscribed because I am interested!
Also thinking about maybe outlining the bumper inserts with LEDs to use as daytime lights.
Reply 0
Feb 15, 2016 | 05:35 PM
Haven't had any luck finding anything similar to this for the sedan. So I'm looking at something like this instead: http://www.ebay.com/itm/2x-30cm-Hond...NTiT2x&vxp=mtr
But I need to find one that is longer than 12 inches.
Reply 0
Feb 17, 2016 | 09:39 AM
Quote: I was interested in adding driving/fog lights to my sedan. I saw a few light kits on ebay/net that replace the inserts on the coupe (lower front bumper) but not one for the sedan. The 05 sedan bumper and coupe look similar from what I can tell but I have not had a chance to compare to a coupe in my area. Has anyone found a "light kit" for the sedan (complete insert)?
For a while Nissan did an OEM driving light kit for the coupe. Long since discontinued, and expensive as well. The aftermarket kits are a cheap copy, not exact to OEM specs.
Anyway, the front bumpers have some subtle differences so it won't directly fit. If you have any fabrication skills you might be able to make it work but I think it would be a little tricky.
In general, I've seen a lot of custom fab DIY attempts to add modern LED style lights to the lower grill area of a G35 sedan. None have looked good.
Reply 0
Mar 29, 2016 | 06:59 PM
I have seen a couple aftermarket LED driving light kits that are really inexpensive ($30). I am thinking about doing the same thing to my 2004 sedan. I'll check back from time to time to see if anyone pulls the trigger on this.
Reply 0
