2005 G35 over heating PLEASE HELP
Old Nov 13, 2015 | 12:52 PM
darryl powell's Avatar
Driving home from work my car stuttered and my check engine light came on and temp shot up to high. I immediately pulled over and popped the hood and the overflow was full and boiling. No smoke , no leaking I let the car cool down and drove off. Next day replaced the thermostat and coolant temp sensor. Check engine light is gone but car still overheating. Someone please help !!
Old Nov 13, 2015 | 12:53 PM
Oh and the fan is working normal ! Comes on about halfway as usual.
Old Nov 13, 2015 | 01:09 PM
CV35Driver's Avatar
Hey there,
Check for air in the system?
Old Nov 13, 2015 | 01:46 PM
Thankyou ! I tried running with the radiator cap off . Do you have another way ?
Old Nov 13, 2015 | 02:05 PM
CV35Driver's Avatar
This is from another post as I am unable to write it out from Mobile.
Unscrew the air bleed screw to the right of the battery. (Large phillips) its plastic
Remove the radiatior cap and fill.
Fill the reservoir in between Low and Full.
Leave rad. cap and bleed screw off and start car, turn heat on full blast.
Let car warm up, put towels under rad. cap and bleed area to catch overflow.
When coolant is visible at bleed screw, put the screw back on tight.
When thermostat opens up coolant/bubbles will rise out of rad. cap. Cap it off now.
Check the level in your reservoir, make sure its in between Full and Low.
Let it idle for a minute or two then turn off heater. Let it idle for another minute and shut off car. Let car cool then check coolant level at radiator and reservoir. Fill to previous mentioned levels.
Should be good to go. Repeat steps if any air is suspect in system.
Hope this helps!
Old Nov 13, 2015 | 04:12 PM
Thank you so much ! I tried and still overheating. Should i try it again. Everything is working and i don't understand. I'm stumped !
Old Nov 14, 2015 | 09:17 AM
Mac8008's Avatar
do you have heat from the vents?
Old Nov 14, 2015 | 09:21 AM
After i bled my system yesterday i just got heat out the vents. But I hadn't had heat for a couple of weeks. Heater core ?
Old Nov 14, 2015 | 12:39 PM
coffeysm's Avatar
If you just started getting heat from your vents after not having it for weeks, I'd say you had a lot of air in your system.
aroundincircles
Jun 12, 2017 11:01 PM
rb25s14
Nov 8, 2015 06:37 PM
NepTuneZ
Vendor Feedback
Oct 15, 2015 05:08 PM
Jwms
Oct 15, 2015 02:38 PM
