I have a question re: 2005 G35 sedan. Difficulty turning over whether engine is cold or warmed up the last few days. Battery replaced within the last 3 months, alternator tested at that time and was okay. Today SLIP and VDC OFF light as well as , service engine soon light came on today. Which I will do. I am just looking for feedback because I don't wanna get hemorrhaged at the dealership. From what I have read I don't think this is a break issue either. The pads were replaced < 2 yrs ago. Oil and fluids have reportedly been topped off at last servce <3months ago.
Thoughts?
Thanks everyone.
Colleen
Thoughts?
Thanks everyone.
Colleen
Go to a shop and have them pull the engine codes to find the specific issue your car is having. To me it sounds like a Cam Position Sensor is going out. But you need to get the code to know for sure and to find out which one needs to be replaced.
I recently had this same problem. Read through this thread for more information:
https://g35driver.com/forums/engine-...-ses-slip.html
Lartytiejdke3
close
- Join DateAug 2011
iTrader Positive Feedback100
iTrader Feedback Score(6)
Liked:989 Times in 825 Posts
They still do
Had one done maybe month or so ago
Was not expecting the name of Colleen to come from a user name of Beaner....lol
telcoman
close
- Join DateMar 2011
- LocationCentral NJ
iTrader Positive Feedback0
iTrader Feedback Score(0)
- My RideFront and rear cameras, tire pressure for all four tires can display on screen,folding side view mir
Liked:197 Times in 178 Posts
Quote:
Don't automatically rule out a battery problem.Originally Posted by beaner
Test the individual cells with a battery hydrometer
What capacity battery did you replace it with? (CCA rating)
Use a voltmeter to measure the voltage across the battery with the engine running. Should read 14.4 v
Telcoman
battery checked out fine, was the CAM sensor.Originally Posted by Ready4aG
Go to a shop and have them pull the engine codes to find the specific issue your car is having. To me it sounds like a Cam Position Sensor is going out. But you need to get the code to know for sure and to find out which one needs to be replaced. I recently had this same problem. Read through this thread for more information:
Thanks to everyone what a big help...beaner Colleen
Seems like I've seen this come up so often lately. Does anybody replace these preventively? I hate the idea of having my car die on my during my 30 mile interstate highway commute. I've got 192k on my presumably original parts (new to me at 160k). Is everyone using OEM replacements or something aftermarket like from rockauto?
Quote:
Quote:
I replaced both when right side cam sensor going bad, my car never die on the road, engine light stay on and harder to start the car... I purchased OEM part via amazon infiniti dealer under $200 for both... take less than hr to replacedOriginally Posted by jbarnett250
Urbanengineer
close
- Join DateJun 2013
- LocationOH-IO
iTrader Feedback Score(3)
Liked:1,045 Times in 960 Posts
RockAuto, autozone, OEM replacements work fine.
