TIFU need help
Old Mar 18, 2016 | 04:32 AM
dat_skyline's Avatar
TIFU need help
So I recently did all of this: replaced both valve covers, replaced spark plugs, replaced knock sensor wire, plenum spacer, replaced necessary seals and o rings.
Now my car is running super rich and has a p0300 code (mult random cyl misfire) it also runs super rough.
No idea what this is, Im pretty sure I reconnected the cps, I'm pretty sure the fuel injectors are correct and I'm pretty sure the coils are connected to the right connector. No I did not get my oil cap rubber stuck in my plenum.
What could it be? :'(
Old Mar 18, 2016 | 07:23 AM
telcoman's Avatar
Veteran: Army
1- Your work
2- being pretty sure
3- not being positive
4- using incorrect or defective parts
Carefully recheck your work
Telcoman
Old Mar 18, 2016 | 10:05 AM
Mustang5L5's Avatar
Was the issue there before?
If not, recheck everything you did. Also, on one bank, it's very possible to swap two of the plugs for the COP's and mess up the firing order.
Old Mar 18, 2016 | 10:58 AM
yosip1115's Avatar
Specifically check the coil pack connectors closest to the firewall on the drivers side and the one directly in front of it (#4 and #6) or verify they are not swapped by checking wire colors. #4 coil should have a gray wire, #6 will have a gray/red wire
Old Mar 18, 2016 | 01:49 PM
Originally Posted by yosip1115
Specifically check the coil pack connectors closest to the firewall on the drivers side with the one directly in front of it (#4 and #6) or verify they are not swapped by checking wire colors. #4 coil should have a gray wire, #6 will have a gray/red wire
I am retarded also I love you, I saw this when roaming the forums but I was too tired at 2am to understand it so I had to ask the forums XD
Old Mar 18, 2016 | 02:02 PM
yosip1115's Avatar
Thgame109
Jun 10, 2023 11:27 PM
J_Burna
Jun 7, 2019 09:46 AM
dat_skyline
Sep 19, 2016 01:05 PM
GARRYDG07
Accessories
19
Apr 26, 2016 07:51 PM
jessex35
Mar 16, 2016 09:10 AM
