Noise from Exhaust/pipe on the back
Old Feb 24, 2005 | 05:17 PM
iafzal's Avatar
The other day and today I heard this vibrating noise from the exhaust/pipe of my sedan when I started cold. Seems like something is loose on the back where the exhaust is or maybe the eschaust is hitting when it is vibrating cold. I heard it when the car was cold in the morning as I happen to go back to get something from the trunk as my car was warming up. It seems to go away after that.
Any ideas or anyone with same problem? solutions??
Thanks
Old Feb 24, 2005 | 10:07 PM
Nickk6's Avatar
It is probably the valve inside the muffler.
Old Feb 25, 2005 | 05:12 AM
subrobo's Avatar
yes, the stock exhaust tip is making the rattle. Next time when you hear the rattle again, you should go down and check if its the tip that is making the noise. Becareful with it, if you try to fix it or lose it...the rusted bolt might just break like mine did, then i change to stillen T-D
rezendvous420
May 31, 2020 01:26 PM
Wayne9011
Jul 27, 2015 11:25 AM
rping
Jul 26, 2015 09:53 PM
apintojr
Jul 23, 2015 10:52 AM
Thaaa_king
Jul 18, 2015 05:56 PM
