Shock bolt removal???
Old May 14, 2016 | 08:21 PM
JoshuaDunand's Avatar
So small problem. As usual canadIan cars are an interesting experience to work on.
I was trying to remove the rear shock for a 350z suspension swap when the bolt snapped
I cut the shock out to make room since it's junk anyway.
Buttt now the bolt is stuck in the bushing and I can't use heat since it'll met the bushing. I tried an impact hammer but it didn't work as well. Any ideas? I need the car running tomorrow
Old May 14, 2016 | 08:24 PM
hurleyguys's Avatar
have you tried penetrating oil? can you just press the whole bushing out?
Old May 14, 2016 | 08:27 PM
I have tried penetrating oil with no luck. I'm sure I could press the bushing out but I need to keep it intact because I need the car first thing in the morning and my local parts supplier that can get parts the same day is closed on Sundays.
Old May 14, 2016 | 08:32 PM
hurleyguys's Avatar
i have pressed old bushings out without any issues to the bushings (at least visually). but i have always been replacing them due to being worn.
can you file the head off it to slip it out?
Old May 14, 2016 | 08:33 PM
hurleyguys's Avatar
can you drill it out. do you have enough room to get a drill on it?
Old May 14, 2016 | 08:38 PM
I may have enough room actually. That's a good idea, maybe I'll give that a shot. Thank you!
Old May 14, 2016 | 08:39 PM
hurleyguys's Avatar
no prob. good luck.
Old May 14, 2016 | 08:52 PM
theronz's Avatar
Drive it as is directly to the shop nearest you and pay them to get it out?
Isn't that a shoulder bolt? You should be able to drill the rest of the shoulder off. Start with a small pilot hole and step up bit sizes until a drill bit about the same diameter as the bolt.
edwinisdumb15
SOCAL Meetings & Events
Sep 2, 2016 03:31 PM
jonblizz
Apr 6, 2016 11:42 PM
g35prelude
Apr 4, 2016 01:57 AM
Popey87
Mar 24, 2016 09:58 PM
Jiggs1219
Feb 25, 2016 08:30 AM
