Noise when turning right, dust shield?
Old May 25, 2016 | 01:02 PM
InfinitiGeeX's Avatar
Only when turning right. Coming from the front left wheel area. Video below.
Thanks
Old May 25, 2016 | 01:31 PM
hurleyguys's Avatar
the frequency of the noise sounds speed dependent. so i would assume prob wheel bearing? not sure tho.
Old May 25, 2016 | 01:33 PM
Both front wheel bearings were replaced last year
Old May 25, 2016 | 01:37 PM
hurleyguys's Avatar
hmmm. maybe a driveshaft then. but i never had an AWD G. so... not sure.
Old May 25, 2016 | 02:25 PM
Mustang5L5's Avatar
It sounds like dust shield scrape. Can you identify which wheel? roll down one window at a time and see if you can identify which side the scraping is coming from.
I'd also just go ahead and pull the wheels off and give the dust shields a quick visual to see if they are close to the rotor.
Old May 26, 2016 | 03:20 PM
Old May 26, 2016 | 03:22 PM
I took of the left front wheel and sprayed the area with WD40 and greased the brakes and the noise has been reduced. It is still there, just not as bad.
I looked at the dust shield and it seems that there isn't any contact with the rotor.
Old May 27, 2016 | 09:10 AM
Mustang5L5's Avatar
Are your pads worn? there are wear indicators that contact the rotor when they are getting worn. Could be one of those
Old May 27, 2016 | 04:02 PM
As suspected, it was the dust shield. It was making contact with the suspension parts.
Feffman
Oct 17, 2016 07:54 AM
JZ
May 23, 2016 12:57 PM
Albanian122
May 23, 2016 09:20 AM
SiouxFallsG35
17 Inch
May 21, 2016 10:02 AM
