Air filter removal
Guest
Posts: n/a
Air filter removal
I just got a K&N replacement filter for my G35 sedan. Only thing is I can't figure out how to remove the air filter. I pulled off the scoop and loosened the bolt holding the assembly but I still can't get the filter out. I could just start taking the intake appart but I just wanted to check and see if there is an easyer way I'm not seeing first. Thanks.
Re: Air filter removal
I went to the dealership and asked them to show me how to change
the filter. It is a little complicated, but I am able to do it in less than
3 minutes. I also bought a K&N air filter. Please see my posting about
K&N filter dilema. My gas mileage dropped with the K&N filter installed,
but I like the acceleration improvemant. How do you like yours?
You need to reset the computer.
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
Take your time any study where your obvious attachment points are. Carefully remove them (taking digital pics is a good idea for future reinstallation purpose) and follow the K&N instructions. It's no more complicated than checking your tire pressure....it just takes longer...lol. You'll get it, and appreciate it that much more 'cause ....You did it yourself. UBCool,jbx
Took me about 15 to 20 minutes trying to think and remove the filter and 1 minute to put the k&n in.
1. I removed the center scoop. (not sure if it is necessary, just thought it would be easier)
2. Remove the bolt near the fender that hold down the box.
3. Release the 4 clips.
4. Push as hard as you can to separate the box and front scoop apart. The box needs to be push back and up so the filter can get out.
5. Drop in the k&n, somehow it is so easy to drop in.
Maybe there is a better way, please let me know.
Originally Posted by zenusXng
Any particular reason why we need to do this part?
Otherwise it takes longer, but will gradually relearn anyway.
C.
Originally Posted by ing35
mtvtech,
So could you show me how to remove the air filter? Thanks.
-Pete
Danielek
May 1, 2022 01:28 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
