Headlight Assembly Compatibility
I just picked up a 2006 G35X Sedan, with the HID headlights. The driver side is cracked and has allowed in some moisture, I am looking to get a used replacement at the junk yard or ebay..
Does anyone know what year G35 sedans/coupes are compatible with each other?
Thank you
Thank you
Thank you! Are the designs inside the headlight assembly any different from year to year or are they all the same?
I drove ttrank's car solo
Received 1,486 Likes
on
I think 03-04 and 05-06 are the two year breakdowns.
Slight changes in the hood/bumper lines prevent a clean swap between the two groups. I want to say they will bolt up, but there will be bad gaps and such.
Easiest way to answer your question is that 2005 and 2006 sedans are the most correct headlight assembly for your car. Coupes are a no go, and the 03-04 sedans may not be a perfect fit if they do bolt up at all.
Blue Dream (01-10-2017)
